Finding deck leaks the overkill way and why duct tape isn't a good idea to seal holes - SailNet Community
 4Likes
post #1 of 19 Old 05-02-2016 Thread Starter
Hello,
First post here! I've found so much helpful advice here that I thought I'd share my experience in trying to find (or rather prove) a deck leak. I've seen threads on this subject, but never any pics or videos.
A friend had a bimini installed last spring, and some attachments came undone over the course of the summer. The canvas maker "sealed" the holes with duct tape over the winter. Come this spring, we noticed there had been a serious leak into the boat over the winter. We wanted to prove he was at fault and resorted to pressurizing the boat's interior with a "squirrel cage" blower and sprinkling soapy water over them to see if any bubbles would come out. They did, and we proved our point.
Worked so well we proceeded to test other deck hardware , and we found a lot of other leaks.
I've attached a few images of the setup. We found leaks in the bimini holes, one chainplate and both cowls.
The takeaway for me is:
  • although it seems more involved than flooding the deck, pressurizing removes a lot of the uncertainty with regards to where a leak might originate. Considering everything, it's probably less of a hassle than guesswork.
  • You will find most, if not all, leaks if you're thorough enough
  • Use 6 mil vapor barrier or a similar strong material.
  • Seal the companionway from the inside, get out of the boat from a hatch, and put a heavy object on the hatch to seal it
  • a 3000cfm blower is totally overkill (we used it at medium setting, which seemed less than half of full speed)
  • Your to-do list will lenghten dramatically after doing this!
I have a video of it all, but am unable to post in the proper forum due to not having enough posts yet. Keep an eye out if interested.
Cheers,
L
senormechanico and seabeau like this.
Niebieski is offline
The Following 2 Users Say Thank You to Niebieski For This Useful Post:
lumpy102 (05-14-2016), senormechanico (05-03-2016)
post #2 of 19 Old 05-02-2016
~~~_/)~~~
Re: Finding deck leaks the overkill way and why duct tape isn't a good idea to seal h
Sounds like a good idea, I've got a mystery leak or two I'd like to find. How much sealing up did you have to do around the mast and the lockers in the cockpit?
Thanks for the idea/extra work!
Lump
lumpy102 is offline
post #3 of 19 Old 05-02-2016 Thread Starter
Lump
Mast is deck stepped, so not much there. As for the lockers, we sealed them while open - wasn't too hard. Just remember to close all the through hulls and seal the ventilation ports. We just stuffed rags tightly in the cowls too... You can get away with an imperfect job if you have enough cfm being pumped in he cabin, as long as the big obvious holes like the companionway are well done.
It was a 2 hour job to get it sealed, and maybe half an hour to remove and clean the duct tape residue with acetone. How long you want to spend spraying everything on the deck with soapy water is up to you, but be careful - it'll make it slippery.
L
post #4 of 19 Old 05-03-2016
Catalina 400 MKII
Scotty C-M's Avatar
What a cool idea. Simple and effective. My brother has been trying to find a deck leak - I'll tell him about this!
Scotty C-M is online now
post #5 of 19 Old 05-03-2016
valis's Avatar
I used this "leaf blower pressurization" method a few years ago, and it worked pretty well. Instead of duct tape, I used painter's blue masking tape to seal the joints. This tape held up to the pressure and left very little adhesive residue.
Paul Elliott
S/V VALIS - PSC 44 #16 - Friday Harbor, Washington
valis is offline
post #6 of 19 Old 05-03-2016
I find that sail tape is the best product to temporarily seal an opening to weather, although, exposed to an entire winter is not temporary.
I would love to give this blower idea a try, but I'm afraid, with a keel stepped mast and a 70ft furling slot to escape air, it's futile.
Jeanneau 54DS
Minnewaska is offline
post #7 of 19 Old 05-03-2016
JimPendoley's Avatar
I'm afraid to find out.....but then again I am afraid not too.
JimPendoley is offline
post #8 of 19 Old 05-03-2016
snake charmer, cat herder
zeehag's Avatar
Send a message via Yahoo to zeehag Send a message via Skype™ to zeehag
the gods pressure wash my boat every summer. new and undetected leaks found annually.. oops. patricia was a rainforest inside boat.....
have fun and best of detection to ye. waterfalls on pillow really suck.
seabeau likes this.
formosa 41, cruising tropics
zeehag is offline
post #9 of 19 Old 05-03-2016
Originally Posted by zeehag View Post
the gods pressure wash my boat every summer. new and undetected leaks found annually........
Ahhh, yes. But knowing you have them and knowing how they got in are very different things..........
Jeanneau 54DS
post #10 of 19 Old 05-03-2016
If you did this on your house you'd probably lift a few shingles and see air escaping there. However you wouldn't necessarily actually have a 'rain leak'.
I wonder if that factor might come into play here? For example the raised shroud/chainplate attachment point blew air.. but might not actually leak (unless submerged, perhaps...)
Faster is offline
Duct tape and fiberglass Kiltmadoc Gear & Maintenance 13 04-11-2011 09:12 AM
duct tape sailboat scottyt General Discussion (sailing related) 6 10-23-2009 12:57 PM
Duct Tape Removal labestia Gear & Maintenance 10 08-26-2009 10:35 PM
filling holes in deck - what tape to use on bottom? LookingForCruiser Gear & Maintenance 6 06-12-2009 10:09 PM
Best tape for temporarily covering holes in deck? GBurton Gear & Maintenance 27 11-28-2007 10:22 PM
