Can I use arborist rope for halyards and sheets? - Page 2 - SailNet Community
 32Likes
post #11 of 60 Old 05-25-2016 Thread Starter
Re: Can I use arborist rope for halyards and sheets?
Why wouldn't you just buy rope that's fit for purpose? You CAN use virtually any rope for sheets. But why would you?
Cost is about 1/4 of the cheapest comparable rope (by specs; see the links in my earlier posts) from West Marine. Of course WM is not exactly a discounter but the difference is huge. That makes a difference when you are talking a few hundred feet of rope.
MastUndSchotbruch is online now
post #12 of 60 Old 05-25-2016
overbored's Avatar
that's climbing rope 3.5% at a very light load( the weight of a person ) is telling you that it is very stretchy line good if you fall the line will give. likely 10% at 30% breaking strength
good halyard line would be less than 1% at 30% of breaking strength.
Climbing rope is also not so good for withstanding UV and salt
MastUndSchotbruch likes this.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #13 of 60 Old 05-25-2016
overbored's Avatar
if one is looking at the dollars then you don't use prices from Worst marine and you don't over size the line just because bigger seems better and it is what you all ready have . the new line is much stronger now and can be sized smaller then in years past. compare the climbing rope to the line that you application needs. 32' cruising boat with 3/8" Sta set would be common and about $ 0.85 a foot. if you really want 1/2" its about $ 1.50 a foot
post #14 of 60 Old 05-25-2016
Moderator
MarkofSeaLife's Avatar
Dock
I bought 12mm (1/2 inch) double braid for a main hallyard. Its breaking load is 3700kgs which is 8,000 pounds. So if you're is rated 5,000pounds its , obviously, a bit less, or cheaper.
One many things: 1 product sold to at a marine store is $$$$... the same product sold inland to poor farmers is $.
Search and research well and you can save a bucket of money.
Beware those who tell you there is only one right way. "Do it properly or you will reget it" is total BS. I say: do it in a safe, affordable way. So a 30 foot cruising boat does NOT need 8,000 pound breaking load line. You could lift your whole boat up and twirl it! Also a halyard need not be zero stretch. You hoist the main. When the wind hits 20 u wind it up another 3 inches. Where's the problem?
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #15 of 60 Old 05-25-2016
Lake Superior Sailor's Avatar
I think you should go of it ! Then come back and let us know how it worked out. Smart men learn from their mistakes..Wise men learn from others mistakes......Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #16 of 60 Old 05-25-2016
Though I have found cheaper prices here and there, these guys are among the best all-round value I've found...
Cajunrope.com - Home
MastUndSchotbruch and seabeau like this.
smackdaddy is offline
post #17 of 60 Old 05-25-2016
midwesterner's Avatar
I hope you try using some of that arborist rope in a marine setting as a test to see how it works and holds up.
Can you use some for sheets and to secure your fenders and report back to us on how it does?
Everything made for marine applications seems ridiculously over priced. I understand that it has to be corrosion resistant in salt water environments, but some of the prices are crazy.
I think that you could take Walmart bottled water and re-label it "Sailor's Agua: (Specifically formulated for marine environments)" and sell it in marina stores for $7 a bottle.
seabeau and northernsquirrel like this.
midwesterner is online now
post #18 of 60 Old 05-25-2016
It does happen of course, but the good 'marine' products are fundamentally different products. Everything from material selection to design is different on marine products, all to meet a very small market with very slow turnover. As a former marine supplier I can promise you our profit margin on marine stuff was pretty much exactly the same as it was for non marine gear, but the costs were higher.
As for this rope... There is zero need for 1/2 rope on a boat this size, the stretch is all kinds of terrible, and the strength is far lower than it should be at this size. Yes you can use it, no you shouldn't.
RichH likes this.
Greg
Stumble is offline
post #19 of 60 Old 05-25-2016
...and inventors and explorers learn from lots of their own mistakes.
post #20 of 60 Old 05-25-2016
Sure that's why they get someone else to support them...Politics are the same!....Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Rub strake for sheets/halyards? Tanley General Discussion (sailing related) 4 05-28-2015 05:14 AM
rope & wire halyards vs all rope halyards kjango Gear & Maintenance 20 03-02-2013 02:16 PM
washing halyards / line / sheets Survivor Gear & Maintenance 18 08-18-2008 01:32 PM
Knot usage for sheets and halyards Zanshin Gear & Maintenance 55 05-15-2007 08:35 AM
Knot usage for sheets and halyards Zanshin Gear & Maintenance 8 04-25-2007 09:35 PM
