Notes on Splicing double Braid - SailNet Community
 8Likes
post #1 of 19 Old 06-10-2016 Thread Starter
I believe that Andy Wall's video on making an eye splice is the best out there.
But he's splicing Nylon, and most of us will be dealing with double braid polyester. Here are some crib notes for mortals who only splice line every few years.
Is it worth it? Defender gets $18 for every eye splice--$20 for 1/2" line and larger.
Notes on Splicing Double Braid - Blogs - EY.o Information Exchange
gamayun likes this.
Christian Williams is offline
post #2 of 19 Old 06-10-2016
Learning the HARD way...
eherlihy's Avatar
Re: Notes on Splicing double Braid
As I have come to expect, another great post!
I used this video (and a couple of others) to help me build a set of lazy jacks; 8 splices in ¼" line in total. By the end, I could complete one in 10 minuites. The step that the video does not mention is to put a blind stich (or four) to lock the splice permanently.
Since then, I have spliced halyards, and traveller control lines with success (well, good enough for me ).
And yes, I used hollow fids and blue masking tape.
SHNOOL and oysterman23 like this.
USCG Licensed OUPV Captain, US/Sailing BKB and ASA 101/103/104/105/106/114/118 Instructor - Also ABYC certified in Marine Electrical Systems,
eherlihy is online now
post #3 of 19 Old 06-10-2016
Freedom isn't free
Dock
I used the same video, great tutorial from NER...
for those who wanted the link to the actual video...
and I used the same thing on VPC (my halyards).
Then I got fancy and did my cascaded backstay adjuster, using amsteel... looks like NER is also to the rescue with a how to.
http://www.neropes.com/Splicing%20Gu...0_Brummell.pdf
My result?
and
Freedom, a 1983 C&C 32 sailing Smith Mountain Lake, VA
SHNOOL is online now
post #4 of 19 Old 06-10-2016
This is very timely. Last night I was trying to put an eye in some 7/16" Yale ULS. It has a 24 weave outer cover which can be tricky to get the fid through.
It took me 4 goes to get right. After the third go, I'd have gladly paid anyone $20 to do it for me. But now there is a certain satisfaction to having got it done.
I anticipated a learning curve, so ordered the line 10ft over the required length! Good thing too, as I used at least that for the 4 eye splices.
I found a good trick at the end, when pulling the core. I put the loop that is tied in the line, at the start, around the hitch ball of my car. Gives you something solid to pull against.
MarkSF is offline
post #5 of 19 Old 06-10-2016
travlin-easy's Avatar
Several years ago, I discovered a quick, easy method of splicing braid from a rigger at Tidewater Marina. I posted a YouTube link to the video of this technique, but for the life of me I cannot seem to find it again. The method was so simple I couldn't believe it.
Essentially, it was just a matter of removing a segment of the core, then using a wire loop, fishing the outer braid through the inside and sewing some locking stitches to hold everything in place. Very, very strong, and it only takes about 60 seconds to make a great looking eye splice in braided line.
Gary
travlin-easy is online now
post #6 of 19 Old 06-10-2016
eherlihy's Avatar
When doing my lazy-jacks, I used the Bowmar 16 winch on the mast as a fixed point to snap the splice. On the last snap, of the last line, the black ring that forms the outer limit of the drum of the winch snapped off, bounced once on the deck, and plopped in the water...
Now the money that I saved by doing it myself was re-invested in a pair of new Andersen 16 winches...
SHNOOL likes this.
post #7 of 19 Old 06-10-2016
I spent the $20 that I saved by doing the splice myself, on the extra 10ft of rope that I ordered to allow for my learning to splice.
Never mind, in another 5 years time, when I need another main sheet, I'll be quids in!
capta likes this.
MarkSF is offline
post #8 of 19 Old 06-10-2016
JimsCAL's Avatar
Originally Posted by SHNOOL View Post
I used the same video, great tutorial from NER... splicing double braid - YouTube for those who wanted the link to the actual video...
Note that NER recommends a core-to-core splice for VPC, not a basic double braid splice.
SHNOOL likes this.
JimsCAL is online now
post #9 of 19 Old 06-10-2016
Master Mariner
capta's Avatar
When I bought the boat, I purchased a spool of 1/2" double braid and did about 20 splices. By the forth or so it was a breeze.
2 years later out comes Sailing Illustrated and things went OK for that splice. 2 years later another one. I almost wish I could do 2 or 3 a month to keep the skill, but if I had to do that I guess my splices weren't very good.
The absolute worst was splicing eyes in our well used jib sheets. Taught me to do the splices in new line and not wait.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #10 of 19 Old 06-10-2016
Here's a question. When I have nearly finished the splice, and I start to draw the eye down towards its final size, every time I seem to end up with the cover longer than the core, so the cover starts bunching up. What is the reason for this, and how do I avoid it?
MarkSF is offline
Splicing double braid Barquito Gear & Maintenance 21 03-06-2015 02:08 PM
Splicing 3-strand line to double braid Zanshin Gear & Maintenance 14 05-15-2013 08:42 PM
Splicing 3-strand line to double braid Zanshin Gear & Maintenance 0 05-10-2013 05:56 PM
Splicing Double Braid BirdBrain333 Pacific Seacraft 3 11-05-2010 11:15 PM
Splicing Double-braid sailak Gear & Maintenance 6 07-20-2010 01:12 PM
