Installing an Edson Cockpit Table - SailNet Community
post #1 of 4 Old 07-05-2016 Thread Starter
Hello, with our 1985 Pearson 303 was a Edson cockpit table and two leaf tables. I have attached pictures.
Any one who has experience to share with installing these tables would be appreciated.
Thank you, Mike
Y KNOT
Pedestal.JPG   Single Table.JPG   Single Table Hardware.JPG   Table Leaf.JPG   Table Leaf Hardware.JPG
Capt Mulch is offline
post #2 of 4 Old 07-06-2016
Sailor
Gladrags1's Avatar
Re: Installing an Edson Cockpit Table
Find the height you want to install the table at. The table in picture 2 attached to a bracket withe the bar that inserts between the nubs on the bracket. See the attached picture for explaination. The second bracket is attached below so to support the table in a level position.. I would recommend drilling holes through the pedestal guard for a permanent installation.
Tod
Sent from my iPhone using Tapatalk
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is online now
post #3 of 4 Old 07-06-2016
JimsCAL's Avatar
Are you missing the SS rod that goes in the hinge? It's easy to lose when the table is removed. You can see it at the top of the table in Gladrags1 first picture.
JimsCAL is online now
post #4 of 4 Old 07-06-2016 Thread Starter
Thank you both for the information! I do have the SS rod for the hinge.
Cockpit table: do it yourself? Plans? geary126 Gear & Maintenance 20 09-16-2014 08:41 AM
Edson cockpit table samson1 Gear & Maintenance 14 03-10-2014 10:36 AM
cockpit table - pine ok? boknows Gear & Maintenance 24 09-30-2013 07:29 PM
Does anyone have an Edson "poly" cockpit table? josrulz Gear & Maintenance 5 02-28-2012 11:36 AM
C30 cockpit table jmabe Catalina 2 02-18-2010 01:50 PM
