New Balmar SmartGuage experience - Page 28 - SailNet Community
 20Likes
post #271 of 281 Old 4 Weeks Ago
colemj's Avatar
Re: New Balmar SmartGuage experience
I'm an IPA guy, so anywhere between 45-50F is good.
Mark
eherlihy likes this.
Dolphin 460 Catamaran "Reach"
Manta 40 Catamaran "Reach" - For Sale!
colemj is offline
post #272 of 281 Old 4 Weeks Ago
bell ringer
Don0190's Avatar
Mark
Well a smart gage can maybe do that
RegisteredUser likes this.
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is offline
post #273 of 281 Old 2 Weeks Ago Thread Starter
Iíve been off the grid for over a week. The banks would generally run down to what the SG thought was low 60s, but the amp hr counter thought was low 70s. Recharging took various forms, from running the generator to intermittent engine use. Twice I ran the generator until Absorb acceptance amps got as low as 0.5%C. I let the bank rest, for about 30 mins, after the generator was shut down, and manually reset the SG to 95%. Despite this forced learning, it would only read 85% on subsequent charges back to Absorb=0.5%C. It just seems to like that level, as noted above.
Odd thing happened yesterday. I had to run the engine for 4 hours, underway. I noted that acceptance amps declined to well under the 0.5%C level, more in the range of 0.1%. I do not have a smart alternator, so it essentially maintains a permanent Absorb level charge. The SG, after those 4 hours, now indicated 93%. Still, it was clearly 100%, but I found it interesting that the SG would only recognize charge over 85%, if Absorb went far past where it should.
Jeanneau 54DS
Minnewaska is offline
post #274 of 281 Old 2 Weeks Ago
I reckon three possibilities, in order of likelihood
a bad unit
incompatibility with the bank type
something wrong with the bank or the install
Since you already apparently have a coulomb counter BM you trust more,
I'd probably put the SG up on eBay as "parts only".
john61ct is online now
post #275 of 281 Old 2 Weeks Ago
Learning the HARD way...
eherlihy's Avatar
Originally Posted by Minnewaska View Post
I’ve been off the grid for over a week. The banks would generally run down to what the SG thought was low 60s, but the amp hr counter thought was low 70s. Recharging took various forms, from running the generator to intermittent engine use. Twice I ran the generator until Absorb acceptance amps got as low as 0.5%C. I let the bank rest, for about 30 mins, after the generator was shut down, and manually reset the SG to 95%. Despite this forced learning, it would only read 85% on subsequent charges back to Absorb=0.5%C. It just seems to like that level, as noted above.
Like you, I do not have a "smart" regulator on my alternator (Leece-Neville 8MR series). I have 2 x 110 AH FLA wet cells connected in parralel as my house bank. I have been playing with a 60 Watt solar panel (actually 4 x 15 Watt panels), and the MPPT controler that was included with the panel to "charge" my house bank. My observation is that the solar panel does not bring the house bank voltage up to 14.x VDC when I connect it. Instead, the voltage starts at 12.xVDC, and as the battery slowly charges from the solar panels, the voltage displayed on the SG slowly raises. As a result the SG does not seem to recognize this as charging the battery at all! The SOC stays right where it was when I connected the solar panel to the batteries. However, if I start my motor, the 90A alternator quickly jumps the voltage over 14 VDC, and the SG SOC starts to rise.
Interestingly, the SOC reported by the $30 BlueTooth battery monitor (BTBM) does recognize the increase in SOC when the solar panel is charging the batteries. Frequently the SG will report 78% SOC and the BTBM will report 80%. While they don't always match the reported SOC, they never seem to be off (in my limited experience) by more than 10%, and are usually within 5%.
Another observation is that the BTBM seems to recognize anything above 13.2-ish (I am not really sure of this number) VDC as charging. Therefore if my batteries are fully charged, such as when I first shut my engine off, this el-cheapo battery monitor will identify the surface charge as charging until the surface charge drops. The BTBM does NOT report SOC while the batteries are charging - this is something that the SG does.
My working hypothesis is that the SG looks at the battery bank voltage only. If the battery bank voltage is over some seceret threshold the SG believes that the battery bank is being charged. The SG then quantifies the TIME above that threshold, and begins to increase the reported SOC as time elapses. If the voltage falls below another threshold then the SG starts to decrease the reported SOC. The further below that threshold the faster the SOC decreases.
Unlike you I am not trying to figure exactly how the SG will report with some exoctic battery chemistry. My goal is simply to keep my house bank viable for as long as possible. For $30 the BlueTooth device seems to meet that need.
Minnewaska likes this.
USCG Licensed OUPV Captain, ASA 101/103/104/105/106/114/118 Instructor - Also certified in Marine Electrical Systems
eherlihy is online now
post #276 of 281 Old 1 Week Ago Thread Starter
Another week of cruising. This past week was on an off the dock, as we took some transient slips.
With the curse of little to no wind, we did quite a bit of motoring, often 4-6 hours at a time. As mentioned above, this motoring would hold Absorb voltage indefinitely, so acceptance amps would decline to a very, very low point. Well lower than the typical switch point to Float voltage. This, however, would cause the SG to read up into the 90s.
I then spent a couple of days off the grid, with SG reading as low as 60, although, the amp counter would imply something in the range of 70 was more accurate. I then had a 30 minute motor to the slip, so the engine did very little to recover charge. I plugged her in and the charger started in Bulk, then switch to Absorb and then to Float, when 0.5%c was reached. The SG, when in Float was reading 76%.
I give up.
I think John is right. It's either a bad unit, or it just can't learn the Gel chemistry correctly or isn't suited to being on and off the dock.
I'm clearly open to an install error, but don't see what that could be either.
Jeanneau 54DS
post #277 of 281 Old 1 Week Ago
SanderO's Avatar
What you can do is actually get the batts completely topped up. Re set the monitor and then keep an accurate log of amps in and amps out. The log should tell you what the SOC is or how many amps you have used... assuming all used amps have not been replaced by charging sources.
This may reveal the accuracy of the monitor... and the SOC you are after.... and perhaps a error correction value????
pay attention... someone's life depends on it
SanderO is online now
post #278 of 281 Old 1 Week Ago Thread Starter
Good thought, SO. I did exactly that with resetting the monitor to Full. Several times. I thought it was 10-15 points off, but this last effort is showing 25 now. It's actually gotten worse.
Jeanneau 54DS
post #279 of 281 Old 1 Week Ago
Probably proven to be not worthy of such a high level of consternation.
And prob ...not needed.
RegisteredUser is online now
post #280 of 281 Old 1 Week Ago
SanderO's Avatar
I f your calculations are complete and accurate... and the meter is not showing this.... it seems that there is a problem in its software.
Alternative to Balmar kellysails Electrical Systems 47 06-09-2016 12:21 PM
Balmar programming kayak1 Electrical Systems 3 05-26-2015 06:43 PM
SmartGuage Review Rusty123 Electrical Systems 13 05-16-2014 04:40 PM
Balmar? scosch Gear & Maintenance 5 03-03-2008 08:45 PM
Blown Balmar? z1nonlyone General Discussion (sailing related) 3 01-30-2003 12:25 AM
