Redoing Companionway hatch - Page 2 - SailNet Community
 3Likes
post #11 of 14 Old 07-22-2016
Re: Redoing Companionway hatch
Originally Posted by Pendragon35 View Post
I found a picture that includes the hatch before it fell apart.
In the picture, you can see the flat teak boards; these have all lifted and come off and that's the part I'm trying to fix. You can also see that the hatch is surrounded by a teak border that I'm trying to retain.
Beautiful Boat. I believe that I would attempt to rebuild entire unit plus slides with a synthetic product, such as PlasTeak or something similar. Both my coach top handrails and companionway slides need replacing and PlasTeak is my choice of repair mediums. If PlasTeak works on these relatively small items I might try it on using it to replace my 1"X 6" covering board, also in extremis.
seabeau is offline
The Following User Says Thank You to seabeau For This Useful Post:
Pendragon35 (07-22-2016)
post #12 of 14 Old 07-22-2016
One of None
deniseO30's Avatar
Pretty boat! Yeah doing a 180 here, keep the teak! it really compliments the whole look. Why the boards came off is a concern ... maybe someone needed it for their boat!
seabeau likes this.
My last project!
deniseO30 is offline
The Following User Says Thank You to deniseO30 For This Useful Post:
post #13 of 14 Old 07-22-2016 Thread Starter
Dock
Yes, I think I've about decided to go back to the original teak boards. My sense is that they came off because the glue up job loosened, allowing water in that lifted them and then they got caught in the high wind storms last spring.So I'm thinking now scrape off all the existing adhesive, put down something else, put boards on. Thanks to everyone for helping me work through this.
Pendragon35 is online now
post #14 of 14 Old 07-22-2016
One of None
deniseO30's Avatar
Flexing probably broke them loose you should be able to fasten & glue from the under side. The joints should be filled with black decking caulk that mimics when tar was used. Tom of Maine just did a project on his boat. I'll look for it.
seabeau likes this.
My last project!
Pendragon35 (07-23-2016)
Tags
alberg35 , companionway , epoxy
Companionway Hatch Donaldpeter Gear & Maintenance 6 06-26-2012 10:09 PM
Companionway hatch wmjr Pacific Seacraft 6 04-25-2012 10:35 AM
Companionway hatch for E-27? captainbrad Ericson 5 09-25-2011 10:46 PM
Companionway Hatch weephee Gear & Maintenance 8 04-25-2010 08:36 PM
Companionway Hatch drh1965 Newport 7 08-15-2008 03:14 PM
