The Future Of In-water Hull Cleaning - Page 2 - SailNet Community
 12Likes
post #11 of 34 Old 08-14-2016
Master Mariner
capta's Avatar
Re: The Future Of In-water Hull Cleaning
Originally Posted by Fstbttms View Post
Tanks? Who uses tanks? These days we work smarter, not harder. And heavy, bulky bottles needing frequent refills are not smarter, chief. Just like dragging an additional hose through the water to run your short-lived pneumatic drill isn't exactly something anybody who does this for a living wants to do.
The point being, unless you have gills, you have an air supply. As for hoses, it can branch off your present air supply hose or whatever you use. No need for dragging anything more and air tools are a LOT more compact and efficient than that thing you are touting for 2k. Plus air powers many more tools than just a brush, for getting in crevices or removing barnacles, etc. I'm not the one with narrow vision in this discussion.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #12 of 34 Old 08-14-2016
travlin-easy's Avatar
C'mon guys, it's a neat, efficient system, and I'm glad to see the vid posted here. Unfortunately, where I'm at the underwater visibility is so lousy you couldn't see where you were cleaning.
All the best,
Gary
Fstbttms likes this.
travlin-easy is offline
The Following User Says Thank You to travlin-easy For This Useful Post:
Fstbttms (08-14-2016)
post #13 of 34 Old 08-14-2016 Thread Starter
I don't discuss my member
Fstbttms's Avatar
You don't know anything about the Remora so you can't know the many features that make it superior to what you are suggesting. Hell, because you have never even used pneumatic tools underwater, you don't understand why the system you are advocating would be ineffective, damaging and short-lived, needing constant replacement.
But that doesn't stop you from coming in here and sh*tting all over the thread.
Fstbttms is online now
post #14 of 34 Old 08-14-2016
SanderO's Avatar
This is very impressive. I send the link of video to Sandy who dives bottoms in Huntington, NY for a living and does mine regularly. And any business will invest in equipment and this seems perfectly reasonable. I don't think I would spend the money for all the gear... but a dive operation should and will recover the investment quickly.
Well done!
SanderO is online now
The Following User Says Thank You to SanderO For This Useful Post:
post #15 of 34 Old 08-14-2016
Wow. That there is one boring video. But that is indeed a cool tool. I think I'll stick with the cotton towel though. The guy here uses a hydraulic-driven disc. I recall it is about 12" diameter. Very fast. But two hoses and a big gizmo-factor. One cannot beat the power/mass factor of the business end of a hydraulic tool.
"...there are two kinds of opinions, those based upon tradition ... and those having something in their favor." B. Russell
aloof is offline
post #16 of 34 Old 08-14-2016 Thread Starter
Fstbttms's Avatar
I wonder how he'd feel knowing he could do the job with a hand-held tool as opposed to an $8000 hydraulic system that requires a boat to move.
post #17 of 34 Old 08-15-2016
I'll take Fast's word for how much quicker it is. The video didn't make that obvious. I suspect the unit is positively or neutrally buoyant? Holding cordless tools on the hard gets old quickly. Can't tell from the vid if it's as gentle as necessary to avoid removing excess paint?
To make economic sense, one needs to have business they are currently turning away to fill the freed up part of the day, or just value going home earlier. Can't see the DIY making good use of it, but I get why the pro likes it.
Jeanneau 54DS
Minnewaska is offline
post #18 of 34 Old 08-15-2016
Being in the biz 50 years ago clearly didn't garner you much expertise if you can't see the benefit to the diver of a small, battery-operated rotary brush system over an air compressor-driven pneumatic tool. And don't you think your system would be in wide use if it were an effective way to go? The proof is in the pudding.
Sweet little device but, at $2K it's out of my budget range. For your pro needs it's great. My one concern is how the seals on it's rotating shaft will hold up long term. Rotating shafts underwater (prop shaft) even the dripless ones always seem to leak at some point.
Mike
Currently: Heading to warm waters over the winter on a variety of boats.
mbianka is online now
post #19 of 34 Old 08-15-2016 Thread Starter
Fstbttms's Avatar
Really? The video is 12 minutes in length and I spotlessly cleaned half of a 39' sailboat in that time. That included getting into my gear at the beginning of the clip and then swimming back to my inflatable after finishing the hull, dropping the Remora off and then swimming the entire length of the boat and starting on the running gear. Maybe you have a different idea of what constitutes "quick" than I do.
The machine weighs about 8 pounds dry. In the water, it is slightly buoyant.
Again, really? Do you see paint being removed in the video? No, you do not. With the proper brush selection and rotation speed, Remora is even gentler to anti fouling paint than cleaning by hand. It certainly provides a more consistent cleaning than doing it by hand.
Not so, and if you were a hull cleaner, you'd know why. This is a very physical job and having a machine take much of the effort out of the work means you aren't putting the wear and tear on your body like you used to. One of my buddies who bought one told me after his first day with it that he just added 10 years to his career.
Of course, there is also an increase in productivity. It's not much of a stretch to say the Remora can add a boat a week to a diver's productivity. At that rate and at our prices (here in the Bay Area), it will pay for itself in less than 6 months. Mine certainly has.
post #20 of 34 Old 08-15-2016
I think the only reason I'm replying is because of the tender responses.
Yes. Really. As you wipe the machine across the surface, it's not obvious how much faster it is. For that matter, there is no way to know, in a film, just how hard the growth was to remove. I have nothing but slime that comes off in a single wipe of any media whatsoever.
Yes. Again Really. There is no way to tell in that video, whether excess paint is being removed. Naturally, it's more than none and less than all. Where exactly is not evident.
I will take your word that it is gentler, which is simply what I asked. Are you taking these questions as critical of you videography? I don't get the tone.
Obviously, you missed my sentence that said I get why the pros like it.
Jeanneau 54DS
Hull cleaning Fstbttms Maintenance/How-to Videos 10 09-09-2015 04:22 AM
Cleaning Hull in the water tapske Gear & Maintenance 66 11-15-2012 02:57 PM
Cleaning old lettering off of a hull jetdrvr393 Gear & Maintenance 14 10-24-2009 02:59 AM
hull cleaning jimmd Gear & Maintenance 3 03-04-2009 01:22 PM
in water hull cleaning? lily Gear & Maintenance 7 03-06-2003 05:07 AM
