Harken Mark IV extruded foil replacements - SailNet Community
 1Likes
  • 1 Post By overbored
post #1 of 10 Old 08-28-2016 Thread Starter
chef2sail's Avatar
Anyone just replaced just one of the foil sections. Seems we were hit by a large bird which severely dented ours 3 feet from the mast head preventing the furler from working.
If so where did you order your part from?
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #2 of 10 Old 08-29-2016
overbored's Avatar
Re: Harken Mark IV extruded foil replacements
that's a big bird. Are you sure it is bent or are the sections loose and coming apart. Any one that sells Harken can get but some want extra shipping because of the length. I have ordered them thru West marine and had it shipped to the store for pickup, no shipping cost or extra length shipping cost that way.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #3 of 10 Old 08-29-2016
Sanduskysailor's Avatar
You are probably looking for a MKIV series 1 or 2 foil. The MKIV foils are different from previous units. You might be in luck as the top foil is usually shorter than the 7' standard length.
Sanduskysailor is offline
post #4 of 10 Old 08-29-2016 Thread Starter
chef2sail's Avatar
Yes it's the top foil of a Mark IV unit 1
It's severely bent you can noticeably see it
Only bird I could think did it is an owl. We have two in nests near the marina. They are huge birds .
Maybe he hit it
Regardless it is bent good enough to affect it turning around the forestay
Parkville, Maryland
Our blog-
post #5 of 10 Old 08-29-2016
The parts list is at http://www.harken.com/uploadedfiles/...F/mk2-1-pl.pdf
You probably need a 807 luff foil. The top foil is usually shorter than 7' so it is cut at time of installation. Any Harken dealer can order one of these for you.
If it were me, I would drop the whole unit. Past experience with separating old foils is to use a heat gun to warm foil at joint to soften the loctite used with screws and connector wedges. A light tap will also help break the connection loose. You can cut the replacement foil to length with a hacksaw but found I had better luck with a Dremel EZ Lock diamond cutting blade. Wrap the foil first with some tape and you will have a nice clean cut.
Good luck
post #6 of 10 Old 08-29-2016 Thread Starter
chef2sail's Avatar
In order to take off the extrusions who forestay needs replacing as the swauge must be cut off to slide it off. Probably means a new forestay also.
Rigger must go to top also.
They said the fitting between the extrusions are not usually difficult for them to get apart each 7 foot length costs $80. I have 7 of them
Parkville, Maryland
Our blog-
post #7 of 10 Old 08-29-2016
overbored's Avatar
don't know why you would have to cut the forestay. most units are installed on an existing forestay. no need to remove the forestay from the mast, the sections are removed one at time at deck level. you heat up the screws with a heat gun to soften the loctite and remove the four screws at each section joint and slide the foil section off.
post #8 of 10 Old 08-29-2016 Thread Starter
chef2sail's Avatar
Bottom and top of forestay have swauges so they. Can be attached to toggle at the bow and masthead at the top. The extruded foil pieces won't just slide off with these in the way. Not sure what type of fittings were used
Parkville, Maryland
Our blog-
post #9 of 10 Old 08-29-2016
overbored's Avatar
that would be a very big fitting to not fit thru the foil extrusion . you need to remove the lower part of the turnbuckle and there should be a swaged on thread fitting. The connectors and bushings fit inside the extrusion and come out before you slide the foil off the wire.
http://www.harken.com/uploadedfiles/...t/PDF/4417.pdf
chef2sail likes this.
post #10 of 10 Old 08-29-2016 Thread Starter
chef2sail's Avatar
Yes I see that. Thanks for the info
I am letting the rigger come look at it this week
If we don't need a new head stay that would be great as that's a simple fix if they can just slide off the whole set of extrusions and just replace the damaged top piece
We have rid rigging and the head stay was replaced when we bought the furler 8 years ago
I doubt the rod is damaged. The issue was being able to get the extruded piece over the bottom swags.
Parkville, Maryland
Our blog-
Harken furler foil section needed Jolly Roger Gear & Maintenance 4 02-26-2014 09:47 AM
Flex foil or aluminum foil for roller furling? fiatracer163 General Discussion (sailing related) 3 12-05-2011 11:23 AM
Harken furler foil replacement seaspot Gear & Maintenance 2 06-10-2010 09:55 AM
Where to get extruded mast section? Gorlog Gear & Maintenance 3 02-18-2010 04:09 AM
Harken Mark II Furling Repair on Pacific Seacraft 37 SVArgo Gear & Maintenance 5 10-17-2007 12:47 PM
