Connect with the world - Page 6 - SailNet Community
 5Likes
post #51 of 51 Old 09-09-2016
Re: Connect with the world
Originally Posted by Minnewaska View Post
Mine is clamped down with what looks like a very small hose clamp. It is then wrapped in rigging tape to minimize tension that would break the wire. The insulated antenna wire is also secured, about every 18", to the non-insulated lower portion of the backstay.
I don't use the SSB much and I suspect this set up to be less than ideal. However, it has worked.
yes!
Cute_Litte_Sicangco is offline
How to Connect to the World at Sea ? HighFly_27 Electronics 4 11-01-2012 10:14 AM
Connect two different sized wire together? SanDiegoChip Electrical Systems 28 02-03-2012 09:39 PM
Connect with Other LiveAboards by Location rgbartist Living Aboard 9 01-19-2011 05:50 PM
Connect or disconnect doubleplay Gear & Maintenance 5 08-28-2003 12:11 AM
