Airmar transducer. - SailNet Community
post #1 of 3 Old 09-03-2016 Thread Starter
jerryrlitton's Avatar
Airmar transducer.
I have an Airmar in hull transducer. What is the best way to secure it (adhesive) to the hull? What type of oil is used inside? Calibration? Also lastly I need a big, easy to read from a distance display. Hard wired is preferred however some wifi options (imux?) I can look at.
Thanks in advance.
Part time PADI instructor, part time sailor. Full time having a blast.
S/V TEMPTATION
Islander 44
jerryrlitton is offline
post #2 of 3 Old 09-03-2016
overbored's Avatar
Re: Airmar transducer.
are we talking P79 depth transducer. best way is to test position first by placing in plastic bag filled with water and put against the hull. or install the mount to the hull with toilet seal wax and fill with water (Mine is still that way a year later and will mount it permanently some day soon ). once you have determined the location works then silicone in place and fill with anti freeze as per the instructions. some will say that if you use silicone your boat will sink but that is what Airmar recommends and it does work fine. http://www.airmar.com/uploads/Instal.../17-217-01.pdf
"GOLD RUSH" PRINDLE 16
overbored is online now
post #3 of 3 Old 09-01-2019
Skipper Jer's Avatar
We have a P79 transducer on our boat. Worked fine for awhile then the readings became erratic. Upon investigation I discovered the anti-freeze had leaked out. The silicone offered very little resistance when I pulled the transducer up. Now I'm wondering why the bond failed. Pretty sure I cleaned the mounting area with acetone. The fiberglass is smooth in the mounting area as is the mounting surface of the ring. I'm thinking to use 60 grit paper to rough up both surfaces before mounting with silicone. Instructions say to use GE silicone I or II. Does anyone have a better suggestion on how to get a permanent mount?
Nor'sea 27
Don't re-accommodate me, Bro
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is online now
Airmar / Raymarine DST800 Transducer Issue wopalx Electronics 44 03-02-2015 06:58 PM
airmar thru hull transducer on pole boknows Gear & Maintenance 11 01-25-2014 09:58 PM
Change Airmar transducer spinwing Electronics 1 05-22-2010 08:30 PM
