Knots in Dynema External mast track brackets? - SailNet Community
 3Likes
  • 1 Post By Minnewaska
  • 1 Post By overbored
  • 1 Post By zz4gta
post #1 of 7 Old 09-08-2016 Thread Starter
My boat has an external mast track. The previous sail had external mast track slides attached with webbing sewn into place. The used sail I bought had the same external slides attached with U-shaped shackles. I had to get creative with the cars that hold the battens. The plastic connectors I tried did not hold up well.
The boat I race on used a spool of cord to make a temporary connector that is still there being temporary. I am pretty sure the material was dyneema or something synthetic like that.
I have a roll of very thin dyneema with a breaking strength of around 800 lbs. I was planning on trying to wrap 4 or more wraps of the dyneema finished with a knot.
Two questions:
Is there a better day to do this other than Dyneema?
If I use Dnyeema, should I use a square knot, double fisherman's or other?
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is online now
post #2 of 7 Old 09-08-2016
Re: Knots in Dynema External mast track brackets?
Are you asking how to attach the slugs to your new sail? I got confused when you mentioned cars and battens. There are several different shackle and clevis products out there. Plastic naturally being the least durable. If you want to tie a slug to a sail, I'm not thinking of a knot that would hold up to flogging for long. If this is for your Potter 14, I bet a heavy-duty zip tie would work in a pinch.
jephotog likes this.
Jeanneau 54DS
Minnewaska is offline
post #3 of 7 Old 09-08-2016 Thread Starter
This is for an Ericson 32. It has a fairly old school mast track and sliders.
The sail has 4 full battens. The batten cars are much thicker and were harder to fit with a bracket. I went through every possible bracket in the shop before settling on the plastic, they did not last very long before breaking.
The sail (used)came with the pieces I have shown in this picture. They work okay but do not have the plastic pieces shown and get stuck a little bit getting jammed sideways when raising the sail.
Pictures attached of the batten car and the brackets used.
Jordan
Oceanside CA
post #4 of 7 Old 09-08-2016
I think the knot in the Dynema will be an issue. There is a way to make a soft shackle with Dynema but I will be surprised if it can be made that small.
This is telling you the obvious, for which I apologize, but I stopped breaking plastic sail shackles when I started making sure the track and the slides (slugs in my case) were well lubricated with dry lubricant.
jimkyle99 is offline
post #5 of 7 Old 09-08-2016
How crazy do you want to get? The right way is to splice a end in one end then cow hitch that to the slide, take a few wraps, I would use as many as will fit and cinch it tight, then use a series of half-hitches to finish it off.
The easier way, and almost as strong is to tie a bolen to the slide then take the wraps then finish with half-hitches.
Greg
Stumble is offline
post #6 of 7 Old 09-08-2016
overbored's Avatar
Dynemma is over kill and does not like to stay tight. use lashing line or sew on with webbing like most sail makers do.
starts at 1:40
baywater likes this.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #7 of 7 Old 09-09-2016
I don't discuss my member
zz4gta's Avatar
+1 to the sailmakers webbing. If you really want to tie things in place, use spiderline or other small dyneema core line with a polyester cover. The cover will hold the knots much better than bare dyneema.
Merit 25 # 764 "Audrey"
zz4gta is offline
Spinnaker Halyards: Internal vs external mast routing mentalfee Gear & Maintenance 5 06-21-2014 05:47 PM
Tape under mast track to separate stainless from aluminum mast preservedkillick Gear & Maintenance 1 05-12-2012 01:37 PM
External tracks on in-mast furling sailnovascotia Gear & Maintenance 1 02-26-2010 09:33 PM
External mast wiring knothead Gear & Maintenance 15 11-06-2008 07:35 AM
Advice on Irwin 28 mast step and spreader brackets msl Boat Review and Purchase Forum 0 04-08-2002 06:00 PM
