Is an Oil Change Required ? - Page 2 - SailNet Community
 2Likes
post #11 of 17 Old 09-20-2016
Re: Is an Oil Change Required ?
I have been advised by mechanics, etc. to move the boat around under power for a while to heat up the oil just before I haul the boat in the fall, then change the oil & filter with boat still on the water while oil is still hot to make it easier to pump out. Once on land I flush raw water side with fresh water (so have to run the engine again, but now with new oil), the boat sits on land for 5-6 months without running engine, then in spring I run engine again before launch. Is that procedure wrong? Do I really need to change it again in spring and run engine during winter?
jmf7654987 is offline
post #12 of 17 Old 09-20-2016
Last thing an engine needs is to sit all winter with acidy oil in the bearings. So a change at haul out??? Unless there is a lot of condensation which will show after a bit of running in the spring and blow off when hot anyway I'd say good to go until hrs are up or winter catches up again .Plugging the exhaust outlet will prevent engine breathing wet air as the barometer rise/fall daily and draining the aqua lift muffler will help too
Capt Len is online now
post #13 of 17 Old 09-20-2016
pdqaltair's Avatar
Remember that the OP has less than 1 hour on the oil. Where did we get the idea it was acidic? At most it has some condensation, but I doubt even that. He didn't run it enough.
(30 years in the lube oil business as a chemical engineer)
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #14 of 17 Old 09-20-2016
I highly recommend a change in lifestyle.
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is online now
post #15 of 17 Old 09-20-2016
Cruisin' for a Bruisin'
On a side note, can you use synthetic in a diesel?
Shrimp
S/V Wayfinder - 1985 Pacific Seacraft 34
cshrimpt is offline
post #16 of 17 Old 09-21-2016
What about residual oil that gets mixed in during the change? Do the additives from the new oil counteract this perpetually?
On diesels, more than gas engines, I find the oil almost instantly starts going off color, even with a filter change. Always figured it was due to higher contaminants in passageways and the pan from the residual oil.
I now get in the habit of running an engine wash, like Amsoil engine flush, in the Spring when I'm putting new oil in for the season. Seems to make a big difference (at first). What's your take?
Jeanneau 54DS
Minnewaska is offline
post #17 of 17 Old 09-22-2016
2ndimpression's Avatar
Send a message via MSN to 2ndimpression
Shrimp
I found a page (which i can't remember were) that talked about using synthetics on older diesels.
Long story short, this guy had a diesel that ran like a top, never burned oil. They put synthetic in it and did a 30 hour transit under power. Bores were mirror polished in the pictures and the diesel burned oil like crazy. I think the motor may of been a Yanmar and when they contacted the company they said it was the oil.
I love synthetic for my car. For my boat, i put in what Volvo says to put in even if it is a extra $10 bucks for their fancy oil.
If i can find that page ill post it. It was a interesting read.
Found it*http://coxengineering.sharepoint.com...htengines.aspx
Knotty
Beneteau 265
2ndimpression is offline
Oil change jagpfd General Discussion (sailing related) 8 10-16-2012 11:26 AM
No oil pressure after oil change brob76 Diesel 30 10-17-2010 12:52 AM
Best oil change pump bestfriend Gear & Maintenance 12 05-19-2007 09:21 AM
W60 - No oil pressure after oil change??? pma_foyl Gear & Maintenance 9 12-01-2004 10:45 AM
Oil Change Pump?? ikent Gear & Maintenance 3 07-22-2003 07:26 AM
