VARIPROP Grease? - SailNet Community
 1Likes
  • 1 Post By Fstbttms
post #1 of 9 Old 11-01-2016 Thread Starter
Maine Member
BELLATRIX1965's Avatar
VARIPROP Grease?
HI all:
Started doing routine feathering prop maintenance today, and RATS - the grease gun went empty. AB Marine sells Variprop/Variprofile "special" grease for $59 a tube. Isn't that special?! The empty cartridge in my gun was the same stuff (soft white grease made in Germany) - but I'm sure that I didn't pay $59 for it (I've had the prop for 9 years)!
Anybody have any thoughts / experience?
BELLATRIX1965 is offline
post #2 of 9 Old 11-02-2016
I don't discuss my member
Fstbttms's Avatar
Re: VARIPROP Grease?
Max Prop recommends Lubriplate 130-AA
https://www.amazon.com/Max-Prop-Feat...riplate+130+aa
olson34 likes this.
Fstbttms is offline
The Following 2 Users Say Thank You to Fstbttms For This Useful Post:
BELLATRIX1965 (11-03-2016), RichH (11-04-2016)
post #3 of 9 Old 11-03-2016 Thread Starter
Maine Member
Thanks Fast - I think that I'll give the Lubriplate a try. That brand has a pretty good reputation. Not only does AB Marine charge $59/tube for their "special" grease, then they want $22 to ship it! Unbelievable!
post #4 of 9 Old 11-04-2016
Lubriplate 130-AA has excellent water resistance. PYI doesn't even require annual re-lubes on the MaxProp, it's every other year with 130-AA. In my experience, even that's conservative.
IStream is offline
post #5 of 9 Old 11-04-2016 Thread Starter
Maine Member
stream: Point well taken but here in Maine I re-grease every fall. The new grease pushes out old grease AND water. Even seawater will freeze when it gets cold enough - and water trapped inside a prop hub . . . you get the picture!
post #6 of 9 Old 11-04-2016
Oh, I'm right there with you. If the boat's out of the water I'm gonna grease the prop even if it was done a week ago. That said, I have let it go two years before and I was very pleased with how much grease was still in the mechanism.
IStream is offline
post #7 of 9 Old 05-31-2017
Hi BELLATRIX1965,
I just wanted to circle back on this post and see if you ended up going with the Lubriplate 130-AA? If so, did you have positive results? I bought a boat last year with a Variprop as well, but the maintenance components (gun, grease, etc.) were not included. I was hoping you may have went with the grease kit that was linked.
Thanks in advance!
iprone is offline
post #8 of 9 Old 06-01-2017 Thread Starter
Maine Member
Originally Posted by iprone View Post
Hi BELLATRIX1965,
Thanks in advance!
Hey iprone:
Yes, I did use the Lubriplate, and am very happy with it. It comes in a tube, so you need the special grease gun pictured in one of the earlier posts - I found one on eBay, I think, and it was under $20. That said, I really like how the tube grease and special gun work - very neat, as that type of grease is really gummy and messy. For your Variprop: check out BoatZincs.com (978-841-9978) - The Online Superstore for Zinc Anodes for a great deal on replacement (OEM) propeller zincs. Enjoy your new boat! OH, and your prop should need a 5mm-.8 grease nipple to apply the grease.
post #9 of 9 Old 06-04-2017
Originally Posted by BELLATRIX1965 View Post
Hey iprone:
Thank you very much for the reply (especially the specs on the grease nipple). I purchased all of the components mentioned, I'm just waiting for it all to arrive.
iprone is offline
Prop Puller for a Variprop Ocean Brezzin Gear & Maintenance 2 04-20-2012 01:22 PM
Wax And Grease nelsonsmoody Gear & Maintenance 4 02-27-2010 05:00 PM
Variprop or Luke feathering props voyagersail General Discussion (sailing related) 4 03-17-2007 10:33 AM
Variprop Experience??? BELLATRIX1965 Gear & Maintenance 1 03-01-2007 10:55 AM
Grease for seacocks KenD Gear & Maintenance 2 02-09-2006 04:19 PM
