Haul out woes - Page 2 - SailNet Community
 10Likes
post #11 of 34 Old 11-05-2016
colemj's Avatar
Re: Haul out woes
Boatpoker, can you answer my question about how the hollow rudder is built?
I recently bought a boroscope that connects to a computer or android device via usb for $15. It seems to work very well. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Mark
Dolphin 460 Catamaran "Reach"
Manta 40 Catamaran "Reach" - For Sale!
colemj is offline
post #12 of 34 Old 11-05-2016
CS rudders were originally made in 2 pieces and bonded together. It is almost certain that most of these rudders will take on a certain amount of water and if stored in an area that freezes it can cause the water to expand and Crack the bond.
robert sailor is offline
post #13 of 34 Old 11-05-2016
Oaksail's Avatar
Re: Haul out woes
I see you're from Hamilton. grinding out the crack and laminating with cloth worked for my cs30 3years ago. relatively an easy fix. Mine cracked on the leading edge behind the skeg. Ive also attached a photo of a friends cs30 rudder that let go coming out of 50 Point late August. We got it back to Bronte with just rope holding the 2 halves of the rudder together. He got it hauled when we got back and he did this Frankenstein repair. It did hold for the rest of the season. He plans to rebuild it over the winter. The one half of the rudder completely separated from the other half.
Fix yours before it gets worse.
I have a CS33 on the hard beside now and i have shown him that his rudder has cracks too!
1989 CS30
Oaksail is offline
post #14 of 34 Old 11-05-2016 Thread Starter
Re: Haul out woes
I like the idea of a borescope.
Bottom line for me is that I intend to sail with my loved ones on this boat. I need to know I've covered the bases and done a good job and that I have confidence in what I've done. I think one or two small holes and a little extra epoxy and glass is a small price to pay.
I never thought to look at Canadian tire or princess auto for a borescope! I know where I'm off to tomorrow!
dailymirror is offline
post #15 of 34 Old 11-05-2016 Thread Starter
Re: Haul out woes
Yep that's it - a crack on the leading edge. I've actually been thinking something more like die grinder may be more appropriate for cleaning out the crack. Maybe give my dremmel a good workout...
What did you use? And how much glass did you have to remove?
post #16 of 34 Old 11-06-2016
Re: Haul out woes
I thought crevice corrosion of stainless steel was from any water, not just salt water? If the rudder tangs have been exposed to water in this fashion for many years, couldnt crevice corrosion take place? Especially at the welds?
xort is offline
post #17 of 34 Old 11-06-2016
Oaksail's Avatar
Re: Haul out woes
I used a dremmel tool to burrow out the crack. You will be removing the the hardened bonding material, not much glass. Fill it with thickened epoxy then cover with cloth, fair and repaint. I think i used 5 layers of cloth.
You should drop the rudder and have a good look at it.
1989 CS30
Oaksail is offline
The Following User Says Thank You to Oaksail For This Useful Post:
dailymirror (11-06-2016)
post #18 of 34 Old 11-06-2016
pdqaltair's Avatar
Re: Haul out woes
What cause the crack? Does anyone know? It seems like the first think you need to know before beginning any repair. There has to be a cause, either underdesign, corrosion, freezing , impact... something.
In this case freezing seems probable, though the said it was dry.
Something caused it. Either the inside grew or the outside shrunk. Which was it, and how do we tell?
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #19 of 34 Old 11-06-2016 Thread Starter
Re: Haul out woes
That seems a lot less scary than having to rebuild the leading edge after removing a whack of glass.
i sure appreciate all the insight and suggestions from all over. Makes the whole issue seem more manageable somehow!
post #20 of 34 Old 11-06-2016 Thread Starter
Re: Haul out woes
I'm only speculating that it was freezing. If the rudder is hollow, I don't think delamination would show up like that - would it? Nor would rust "jacking". I suppose it someone foam filled it in the past as poatpoker suggests disintegrating wet foam would expand and do this.
When work gives me a break I'll go drill a drain hole and perhaps put a borescope to work. I'll let you know what I find.
Reverse Woes GaiaOrion General Discussion (sailing related) 9 08-08-2010 11:22 AM
Reefing woes adamowens Pacific Seacraft 13 05-17-2010 07:39 PM
Insurance Woes Zingaro Cruising & Liveaboard Forum 13 05-12-2010 05:55 PM
Alternator woes mikethecapt Gear & Maintenance 2 03-08-2008 04:46 PM
