Installing ST winches, do I still need cleats? - SailNet Community
 1Likes
post #1 of 12 Old 11-19-2016 Thread Starter
I'm guessing the answer is yes? For safety/redundancy?
dixiedawg is offline
post #2 of 12 Old 11-19-2016
al brazzi
Re: Installing ST winches, do I still need cleats?
No point in removing them I guess, extra cleats are nice for tying up in a storm and such. Your self tailers should be fine without them.
albrazzi is offline
post #3 of 12 Old 11-19-2016
Sailor
Gladrags1's Avatar
While your self tailers are fine without cleats, I'd keep them as they are good in case of a storm.
Sent from my iPhone using Tapatalk
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #4 of 12 Old 11-19-2016
When singlehanding in light to moderate winds, you don't really need the self-tailer. In fact, using a self-tailer in those conditions is awkward and slow. In lighter winds, I use the winch without putting the line in a self-tailer. Then I wrap the line once around the jam cleat that was installed by the boat builder. It's quick, easy and secure. Jam cleats have no moving parts and never wear out or break. I suggest you have some type of cleat that you can use easily in lighter winds, when you don't need to grind the winch with a winch handle.
RobGallagher likes this.
Sailormon6 is online now
post #5 of 12 Old 11-19-2016
Learning the HARD way...
eherlihy's Avatar
What kind of boat are we talking about?
I use the winch & the self tailers all the time on my O'day 35. I may not put as many wraps around the winch in light air, but the winches are how I manage my genoa sheets.
I use the cleats that were originally installed for the sheets when I tie or hip-tow the dinghy. I also find that the cleats are very useful when tying up in the slip.
There is no reason that I can imagine to remove the cleats that you have, you'll just use them for other purposes.
USCG Licensed OUPV Captain, US/Sailing BKB and ASA 101/103/104/105/106/114/118 Instructor - Also ABYC certified in Marine Electrical Systems,
eherlihy is offline
post #6 of 12 Old 11-20-2016
Master Mariner
capta's Avatar
We haven't used a cleat with our selftailers in the 7 years we've been sailing the boat. Not ever, in any conditions and so far we've had sail up in 70 knots of wind. They are just in the way and I fully intend to take them off one day.
The cleats around the cockpit are not large enough for us to use with dock lines, nor in any position to do so.
As the weather gets up we add more turns, up to six on the 65's.
I don't see how selftailers are any slower than manual tailing; the winch still turns at the same speed, you just have both hands to crank with if one uses the selftailing feature, which I assume would actually make the winch go faster, if one wished.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #7 of 12 Old 11-20-2016 Thread Starter
Yes, but what about in BAD weather?? LOL
Actually it's two different boats, a Catalina 22 and an Albin Vega 27. Both are getting their winches replaced with ST's at the Admiral's request - and because I got a steal on both pairs of ST's.
Thanks for all the responses! It appears that the answer is not 100% clear cut, and not "definitely keep the cleats" like I thought it might be. I'd really like to remove the cleats if they don't have a good reason to be there anymore. Actually they're already gone on the C22, and I'd rather not have to put them back - again, unless there's a good reason to.
Thanks again!
post #8 of 12 Old 11-20-2016
pdqaltair's Avatar
I sometimes take the tails out of the selftailers and put them in cam cleats when sailing fast in gusty weather. I also reduce the number of wraps by one. This allows me to release the sheets more quickly from anywhere.
That said, I'd keep a few horn cleats handy. It seems like something comes up once in a while.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #9 of 12 Old 11-20-2016
overbored's Avatar
boats built new with ST winches did not come with cleats so why would you need them. horn cleats are a good place to get lines caught on. sometimes when I need an extra place to cleat a line I will use one of the cabin top ST winches like a cleat.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #10 of 12 Old 11-21-2016
fallard's Avatar
Off topic, but what was your sail plan in 70 kts? Do you have storm sails?
fallard is online now
cleats Woodfinatic Gear & Maintenance 22 09-24-2014 10:04 PM
Mast cleats, how many preservedkillick Gear & Maintenance 1 05-28-2012 09:49 AM
Installing new Harken radial winches Irunbird Gear & Maintenance 6 04-28-2012 01:42 PM
Replacing Cleats wchevron Gear & Maintenance 13 04-02-2008 01:55 PM
installing Swivel Cleats - loads and mounting? Lancer28 Gear & Maintenance 21 10-01-2007 01:11 AM
