Plexiglass window thickness? - SailNet Community
post #1 of 9 Old 12-08-2016 Thread Starter
I'm in the process of replacing the leaky old tempered glass windows in our Albin Vega with dark smoked Plexiglas. The plan is to use the two-side tape and Dow795 method, no fasteners. The windows have no curvature, and the openings are about 7" tall by 48" long.
Does anyone have any industry inside information, strength data, or hard-earned personal experience to help me determine the appropriate thickness to use?
dixiedawg is offline
post #2 of 9 Old 12-08-2016
Re: Plexiglass window thickness?
I suspect the trim is leaking not the glass. Tempered glass can be restored with auto glass restoration products.
Choices for trim restoration depend on how bad the gasket material is but there is also a wide range of rubber/vinyl restoration products available at most auto parts stores.
Try repair/restore before replace.
Ulladh is online now
post #3 of 9 Old 12-08-2016
If you do go with plexi, go with the same thickness as the OEM glass.
If you are changing mainly to get the tint, you can get tinting film and apply it to the automotive glass cheaply and easily.
The automotive grade glass is better than plexi in just about every way possible.
Turnin Turtle is offline
post #4 of 9 Old 12-08-2016
travlin-easy's Avatar
Ditto!
travlin-easy is offline
post #5 of 9 Old 12-09-2016
mitiempo's Avatar
As you are not using the original frames you are not restricted to thickness. As there is no curvature also that doesn't restrict thickness. I would suggest 1/4" to 5/16" possibly, maybe 3/8".
I agree with the method and will be doing the same myself.
Brian
mitiempo is offline
post #6 of 9 Old 12-09-2016 Thread Starter
Thanks, Brian. In that case, you should take a nice Christmas vacation to Florida and help me install these things. That way, you'll be all practiced up and ready to tackle yours in the spring!
No need to thank me.
post #7 of 9 Old 12-09-2016
fallard's Avatar
If the original material was tempered glass, why not replace in kind? You can order a replacement from your local glass/mirror shop. You'll need a template--the old glass,if intact will do.
BTW, my replacement port lights were 1/2" plexiglass.
fallard is online now
post #8 of 9 Old 12-12-2016
Tundra Down
downeast450's Avatar
Why not 3/8" cast acrylic?
Down
Islander-28, Marshall Sandpiper
downeast450 is offline
post #9 of 9 Old 12-12-2016
My hatch is 1/2-inch plexiglass. You can stand on it without fear of breakage.
Gary
polycarbonate window thickness? andyselzn Gear & Maintenance 16 06-30-2014 11:01 PM
Plexiglass hatch question Parclan Gear & Maintenance 2 06-30-2010 02:36 PM
Plexiglass dodger window sailboy21 Gear & Maintenance 1 02-15-2008 08:35 PM
plexiglass or lexan prussell Gear & Maintenance 1 04-23-2004 02:17 AM
plexiglass or lexan prussell Gear & Maintenance 2 04-22-2004 08:59 PM
