Stray AC current testing - Page 9 - SailNet Community
 28Likes
post #81 of 81 Old 04-30-2017
Mermaid Hunter
SVAuspicious's Avatar
Re: Stray AC current testing
Originally Posted by Minnewaska View Post
I also re-tested continuity between neutral on the two cords, when unplugged but set to shore power. It was POSITIVE continuity. I highly suspect my helper below wasn't setting them correctly last time.
Electrician to separate the neutrals is on order.
The electrician will likely think of this: the selector switch(es) may not be wired correctly causing the neutral connection. Depending on your generator and/or inverter neutrals may need to be connected on board but obviously not on shore power. Same with ground-neutral bonding.
The solution may indeed be splitting a combined neutral bus but could be as easy as moving wires from one side of the selector switch to the other IF there are enough poles on the switch.
Junglejetjay likes this.
SVAuspicious is offline
Stray 60 millivolts, a problem? ereiss Electrical Systems 0 08-25-2013 08:57 AM
Fridge Compressor Corrosion - Stray Current? zul Gear & Maintenance 4 08-15-2012 09:08 AM
stray voltage? victoria28 Electrical Systems 6 04-05-2010 04:19 PM
SSB Question re: Stray RF Energy danielgoldberg Gear & Maintenance 15 03-24-2008 03:39 PM
Fish Zincs, Pencil Zincs and stray current gcalahan Catalina 0 04-18-2007 09:27 PM
