FTZ battery lug crimper - Page 2 - SailNet Community
 5Likes
post #11 of 32 Old 02-08-2017
Marine Refrigeration
Re: FTZ battery lug crimper
Originally Posted by hellosailor View Post
Since those hydraulic crimpers are always for metric wire sizes ("9x dies: 4, 6, 8, 10, 16, 25, 35, 50, 70mm2 ") they will not properly crimp SAE or AWG wire sizes, found in the US. And of course, everyone "in the business" in the US insists that properly sized dies are critical, that "close" is not good enough.
Leaving the question of why some clever Chinese tool maker doesn't supply US die sizes for the US market. (shrug)
Or, perhaps close is good enough and all the sized dies business is nonsense?
Trust me , I had my reservations about these hydraulic crimper’s , I have a couple of crimper’s that have standard dies that have not worked well in the past so I thought I would give this one a try , for the money , why not. I wanted to make sure these crimps would handle the current I was going to put through them ,300 amps, so I cut open a couple of them to take a look at how well it was working. My tests showed full engagement and fusing of the strands, no voids! So maybe that SAE die thing is nonsense ? Best money I have spent in a while .
Regards John
ColdEh Marine is offline
post #12 of 32 Old 02-08-2017 Thread Starter
I contacted sailboatowners.com to let them know I didn't receive instructions. Since I posted this morning, I've also noticed that some of the lettering on the dies is illegible. Something is goofed up. I have a feeling this was a return to someone else along the way and SBO didn't know it. They are sending me another one today and are taking this one back.
Good service.
Jeanneau 54DS
Minnewaska is offline
post #13 of 32 Old 02-08-2017
I have this one:
https://www.amazon.com/Greenlee-K09-...eenlee+crimper
All the dies are both numbered for their nominal wire size and colored. You can't rely only on the wire gauge markings on each die because different lugs come in different thicknesses. The Ancor starting lugs are made of thinner stuff and they crimp fine in the corresponding numbered die. The FTZ lugs for the same wire size are thicker so you need to go up a die size. In that case, the color coding on the lugs tells you the proper die size.
Bottom line, go with the color markings on the lugs. If there is no color marking, go with the nominal wire size.
IStream is offline
post #14 of 32 Old 02-08-2017 Thread Starter
I also bought FTZ heavy duty lugs, as these will go from the 125 amp inverter/charger directly to the battery.
Update from sailboatowners.com, who are being very helpful. They opened another box, before sending it out, and found it also doesn't have instructions, nor was the die lettering very crisp. They said the tool is now made in China, it's used to be made in the US. @Maine Sail may update his recommendation.
Jeanneau 54DS
post #15 of 32 Old 02-08-2017
The Greenlee isn't cheap but it's very good. Made in Germany, FWIW.
IStream is offline
post #16 of 32 Old 02-08-2017
Super Moderator
Maine Sail's Avatar
FTZ 94284 Calibration
#1 Set the left die to "A"
#2 Set the right die to "C"
#3 Open handles fully
#4 Close handles until the "A" die and "C" die first touch
#5 Do not close handles any further (dies just touching)
#6 Measure the distance between the handle centers at the handle ends
#7 Distance should be 14" - 16" center to center
#8 If not 14" to 16" turn the Allen head adjusting screw (on right handle side of tool above sticker) clockwise to widen the handle gap and counter clock wise to narrow the gap.
#9 Hint closer to 14" and the crimp is on the low side of adjustment (less tight), closer to 16" and the crimp is tighter.
SVTatia, Rhapsody-NS27 and seabeau like this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #17 of 32 Old 02-09-2017 Thread Starter
Thanks Maine. Starting measurement was 20 inches! Here's a pic of the quality, which is the same die setting in one of your pics on your website. I've also included a pic of the cause. SBO has offered to replace it, with one I can read. Although, they say they are all fuzzy letter stamping.
Jeanneau 54DS
post #18 of 32 Old 02-09-2017
There you go Minne, Maine beat me to it...
On mine one letter is also fuzzy, but you sort of get used to it... Interesting enough when I first saw Maine Sail's article the cost was under $150 now it is up to $180 - price going north quality going the other way....
In any case, its a good tool and the cost per crimp on mine is getting lower everyday.
SVTatia is online now
post #19 of 32 Old 02-09-2017
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Got mine here. Probably the best price I was able to find.
FTZ Heavy Duty Lug Crimp Tool
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
post #20 of 32 Old 02-09-2017
Old as Dirt!
svHyLyte's Avatar
For what it's worth, while installing our Maxwell windlass in 2006, I found that connecting lugs to the cables needed was much more easily and neatly accomplished by using a "SwageIt" hand swaging tool:
The "SwageIt" was also far less costly than a crimping tool.
chef2sail likes this.
svHyLyte is offline
AMP/TE 58433-3 Crimper good replacement for Ancor 703030? mrjaw14 Electrical Systems 8 09-16-2016 11:42 PM
Harbor Freight Tools - Crimper Update Maine Sail Gear & Maintenance 132 05-03-2014 11:33 PM
Battery Cable Crimper Tree Gear & Maintenance 21 01-01-2013 06:37 PM
Balanced Lug Sail Ulladh Gear & Maintenance 2 03-19-2012 11:32 AM
Main sail lug attachment question davidpm Boat Review and Purchase Forum 6 07-18-2011 08:40 PM
