FTZ battery lug crimper - SailNet Community
 5Likes
post #1 of 32 Old 02-08-2017 Thread Starter
Just bought this crimper to make new cables for my new invertor/charger. I figured it would pay for itself, when I expand my house bank down the road.
It came with no instructions, other than the settings on the handle. I assume I crimp down as hard as I can? Turn 90 degs and crimp again? It also came with a small screwdriver, allen key and allen bolt. No idea what the additional allen bolt or screwdriver are for.
Jeanneau 54DS
Minnewaska is offline
post #2 of 32 Old 02-08-2017
Re: FTZ battery lug crimper
I have one of these. Awesome tool.
Mine came with a little paper with instructions on how to calibrate the crimper prior to use.
I remember seeing another post about it here or somewhere else, I'll dig it up. The tools are to use in the calibration.
To crimp you just follow the guide on the handle for the lug size you are using, dial the right dies (left and right) and crimp - place one of the handles on the floor and hold the wire with the other. It does not need to double crimp unless you are using the double crimp lugs.
I assume you have seen this?
http://www.pbase.com/mainecruising/battery_cables
SVTatia is offline
post #3 of 32 Old 02-08-2017 Thread Starter
Originally Posted by SVTatia View Post
....Mine came with a little paper with instructions on how to calibrate the crimper prior to use...
Good to know it needs calibrating. Nothing came in the box, I just double checked. If you have anything, I would greatly appreciate it.
Sure have. I purchased the crimper from the link in MaineSail's article.
Thanks again.
Jeanneau 54DS
post #4 of 32 Old 02-08-2017
Marine Refrigeration
I actually bought one of these. It has worked flawlessly and makes a nice 6 sided crimp.
10 Ton 9 Dies Hydraulic Wire Terminal Battery Cable Crimper
This is one of my crimps on 4/0 Ancor wire .
Regards John
PS you can see my wire cutters beside my foot on the floor, the handles are 4 feet long LOL slices 4/0 like butter .
ColdEh Marine is offline
post #5 of 32 Old 02-08-2017
Sure have. I purchased the crimper from the link in MaineSail's article...
Same here. I'll look for the instructions and let you know, its fairly easy...
Minnewaska likes this.
SVTatia is offline
The Following User Says Thank You to SVTatia For This Useful Post:
Minnewaska (02-08-2017)
post #6 of 32 Old 02-08-2017
Regards John
Sorry, Wrong one,
This is the one I used , the dies are held on both sides .
16 Ton 11 Dies Hydraulic Wire Crimper Crimping Tool Battery Cable Lug Terminal | eBay
Regards John.
post #7 of 32 Old 02-08-2017
Since those hydraulic crimpers are always for metric wire sizes ("9x dies: 4, 6, 8, 10, 16, 25, 35, 50, 70mm2 ") they will not properly crimp SAE or AWG wire sizes, found in the US. And of course, everyone "in the business" in the US insists that properly sized dies are critical, that "close" is not good enough.
Leaving the question of why some clever Chinese tool maker doesn't supply US die sizes for the US market. (shrug)
Or, perhaps close is good enough and all the sized dies business is nonsense?
hellosailor is offline
post #8 of 32 Old 02-08-2017
Daniel - Norsea 27
Rhapsody-NS27's Avatar
I got the FTZ crimper per Maine Sails recommendations as well... along with the one he sells for heat shrink ring terminals.
Ordered some lug terminals from genuinedealz for 2 AWG that only says "pink die" on it. I set according to what's on the handle then did a crimp, but it seemed too small as part of the lug was squeezed out one side of the crimper, so I went to the next size up and had a better crimp. Same thing happened when I got a different terminal that only said to use "brown die" and had to re-adjust after the first crimp.
Certainly a good crimper for working on the boat and crimping terminals while the wires are in place. Not much room for the hammer crimper I have on hand.
I also got a piece of paper with mine, but just set everything to the side for now. Didn't see a need to use those bits at this time.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
post #9 of 32 Old 02-08-2017
Master Mariner
capta's Avatar
Sorry, Wrong one,
Regards John.
I have a similar one from Harbor Freight which works great on everything from battery lugs to the davit cables and dink security cables. 6 years and still going great.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #10 of 32 Old 02-08-2017
Originally Posted by Rhapsody-NS27 View Post
... but it seemed too small as part of the lug was squeezed out one side of the crimper, so I went to the next size up and had a better crimp. Same thing happened when I got a different terminal that only said to use "brown die" and had to re-adjust after the first crimp.....
Looks like your crimper needs calibration...
... I also got a piece of paper with mine, but just set everything to the side for now. Didn't see a need to use those bits at this time.
Go get that piece of paper and fix it....
SVTatia is offline
AMP/TE 58433-3 Crimper good replacement for Ancor 703030? mrjaw14 Electrical Systems 8 09-16-2016 10:42 PM
Harbor Freight Tools - Crimper Update Maine Sail Gear & Maintenance 132 05-03-2014 10:33 PM
Battery Cable Crimper Tree Gear & Maintenance 21 01-01-2013 05:37 PM
Balanced Lug Sail Ulladh Gear & Maintenance 2 03-19-2012 10:32 AM
Main sail lug attachment question davidpm Boat Review and Purchase Forum 6 07-18-2011 07:40 PM
