Practical Sailor anchor testing - Page 2 - SailNet Community
 13Likes
post #11 of 14 Old 03-07-2017
fallard's Avatar
Re: Practical Sailor anchor testing
Originally Posted by pdqaltair View Post
The best you can do, IMHO, is read a lot of data, and then learn how to set and test an anchor properly. The truth is that you can safely anchor with most any anchor, if it is sized properly and you know how best to use it. We all have our favorites, and I'm not going there!
Agree. There are so many variables that it seems silly to presume a single style anchor is "best", without consideration of bottom type (including shallow strata) and--particularly--scope and setting.
I've got a Mantus dinghy anchor and it is impressive for its quick setting and holding power, compared to other compact dinghy anchors. I bought the version that breaks down without tools and stows in my bow compartment. My other choice would have been the small Fortress, but I couldn't stow it without taking it apart. The mushrooms and folding grapnel are totally inadequate IMHO. Thus, I can appreciate the enthusiasm for "modern" --Mantus, Manson, Rocna--styles, but don't think they are the only answer.
My primary sailboat anchor is an "old-fashioned" CQR, which has served me well for 21 years. There was a learning curve, though. I figured out how to start the set, back down progressively, and let out more scope. It probably helps that I have a 3-bladed MaxProp that provides significant thrust in reverse, compared to fixed, cupped props. For overnight anchoring, I typically back down at a peak rpm of 1600 rpm with my 3GM30.
Bottom line: anchoring technique matters, regardless of anchor type.
fallard is offline
post #12 of 14 Old 03-07-2017
I am not sure this is a recent report.
The conclusions seem very strange. They are not consistent with other findings.
I have not read the report, but given the strange findings, I don't think it worth the time and cost of paying for the details.
Practical Sailor has some very good information, but the anchoring articles are very inconsistent in my view. Some are good, but many are terrible. I think the magazine needs a revision of its contributing authors in this area.
Formally noelex77, but I cannot access that account.
Noelex is offline
post #13 of 14 Old 03-07-2017
pdqaltair's Avatar
I have. It book is primarily a compilation of articles written over a considerable time period. Some is new, and some of the reports are older, including anchors of older designs; I'm not sure that is bad, since they are still around and this gives a reference point for newer designs. Additionally, some of the material relates more to rigging methods, chain and connectors. There is a LOT more to anchoring than performance numbers from a test method that can never exactly duplicate the real world. That said, I've certainly mined them (3 books) for information. Data is always useful, and more experiences always help. Considering the cost of learning by hard knocks, books are always cheap.
I think terrible is a stretch. Anchors tend to be an area where opinions run high. What you are likely seeing is a range of views based on a range of experiences. I certainly don't agree with all of them, but I respect that different boats and different cruising areas require very different answers.
Let me give an example. There was a big test in mud near Solomons Island, MD a few years ago. Lots of data, carefully witness and recorded. You could nit pick through the numbers and reach many conclusions, but I'm pretty sure only a few are truly supported by the data:
* Anchors don't hold much in soft mud.
* More surface area helps.
* Layers do weird stuff to anchors, and you can't judge the layers from the surface.
* Anchors can take a long distance to set in soft mud. All of them took 30-60 feet.
* The angle of the fluke matters; shallow is better in firm bottoms, steep is better in soft bottoms. It is no more possible to pick a perfect geometry than it is possible to use chef's knife on a tree, or a chainsaw on a tomato.
Excellent anchors under performed, and mediocre anchors did relatively well. Anchor testing on poor bottoms is a bastard, which is why very few people even try. How many tests have you read on very soft mud, weeds, or rocks? You won't because it is agony.
I don't believe ANY brand-specific statements can be supported, based on the amount of scatter in the data and the variable nature of the seabed.
fallard likes this.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #14 of 14 Old 03-07-2017
Yes. This is part of the problem. It is very rare to see even rudimentary statistical analysis on the results.
BTW, I have enjoyed your writing.
Noelex is offline
Practical Sailor magazine Pamlicotraveler General Discussion (sailing related) 15 03-23-2014 08:14 AM
Practical Sailor Anchor Plug LinekinBayCD Gear & Maintenance 41 01-24-2011 08:19 PM
Practical Sailor Kiltmadoc General Discussion (sailing related) 23 01-04-2011 07:18 AM
Sometimes Practical Sailor is NOT So Practical..? Maine Sail Gear & Maintenance 31 06-03-2008 02:04 PM
Practical sailor mag. ptsbug General Discussion (sailing related) 22 01-03-2007 07:04 PM
