Cabin sole wavy - can you level it? - SailNet Community
post #1 of 6 Old 04-03-2017 Thread Starter
I am replacing the teak/holly plywood in my Seaward 25. When I removed it, there is a recessed pan that the floor should fit into. However, the floor underneath it varies in height by at least a 1/4" in some spots, due to the keel bolts. At some point in its life, the floor was replaced by indiscriminately filling that pan with huge squirts of adhesive and then flooring over the top of the recessed pan.
I thought it might be the fact that the boat is sitting on the trailer on the keel, so I adjusted the posts on the trailer to lift it slightly off of the keel. There appears to be no change.
At this point, I think I may just wish to level the floor. I was going to get the boat level on the trailer and then try to use some flooring leveler. Perhaps I should just use a ton of epoxy? After I do that, I will epoxy the PlasTeak to the floor as per PlasTeak's directions.
I'm worried that flooring leveler may not be flexible enough. I did see a product called Seacast that looks promising.
So, any ideas? Product suggestions? Shared experiences? Solutions?
Thanks,
Mark
mneidin is offline
post #2 of 6 Old 04-03-2017
Re: Cabin sole wavy - can you level it?
Pictures would help... how thick is/are the sole plates? Can you recess the bottom surface to take the uneveness into account so that the floor board(s) actually do sit flat without weakening the sole?
Faster is offline
post #3 of 6 Old 04-03-2017
I don't understand the 'pan'....can't visualize/mentualize it....
RegisteredUser is online now
post #4 of 6 Old 04-03-2017 Thread Starter
The floor is molded fiberglass. Where the teak/holly plywood went, they recessed the fiberglass about a 1/4" so that the teak/holly would fit flush. However, due to the wavy-ness of the recessed area, I can't put the PlasTeak directly on it. I need to level what will be the subfloor, before I can put the new floor on it.
mneidin is offline
post #5 of 6 Old 04-03-2017
overbored's Avatar
I had a similar cabin sole in my last boat and we covered it with Lonseal lonwood teak and holy. lonseal and plasteak vinyl flooring are the same thing. curved surface would have been very hard to do with wood. we used the satin top seal finish because tested a sample of all three finishes on the cabin sole. the satin finish was the least slippery when wet and it showed less marks from boat shoes. 6 month test. we leveled the surface with west epoxy and micro balloons. I looked into the seacoast but it is polyester resin and chopped glass fibers and very hard to sand if needed. the lone seal was stuck down with their epoxy compound which works very well. small learning curve, use a small 1/8" notched trowel and use a floor roller to make sure it is down flat and roll out any excess resin. don't even try without the roller
"GOLD RUSH" PRINDLE 16
overbored is online now
post #6 of 6 Old 04-03-2017
From your description the previous owner 'shimmed' the recess to make the sole level using some kinda whatever.
This makes sense.
I would suggest the same, topping the 'whatever fill' with wax paper, then lightly weighting it.
The PO may have only put a few sploches in, but you could fill most of the recess so weight is spread evenly.
Otherwise, you're talking about messing around with composite shims (cheap), but still needing to glue them down.
Maybe think about this as a gasket...pressing the sole to the flexible gasket sets an even height/level.
Would have to be there....
A carpet runner hides a lot of ills....
cabin sole don sanford Pacific Seacraft 12 10-04-2015 03:26 PM
Putting in new floors and a cabin sole. Also planning a new cabin layout. Advice? sully75 Gear & Maintenance 4 10-02-2013 02:30 PM
Cabin sole sandyv38 C & C 3 12-17-2010 01:53 PM
Cabin sole Dcneuro Gear & Maintenance 16 09-27-2008 08:34 AM
Cabin sole drynoc Gear & Maintenance 5 12-16-2003 03:36 PM
