Rope connector... what is the name of this?? - SailNet Community
 4Likes
post #1 of 12 Old 04-10-2017 Thread Starter
I have this piece on the end of my main halyard that creates an eye to connect to the old wire halyard. I am trying to find this piece so I can buy just a replacement halyard rope for now to connect and avoid replacing the sheaves for all rope halyards until later this summer.
Does anyone know the name of this piece? I went to Fisheries Supplies and they didnt seem to know.
Thanks.
fr500c is offline
post #2 of 12 Old 04-10-2017
Re: Rope connector... what is the name of this??
If it's a short term fix that won't go over the sheaves now anyway, just tie the rope to the wire thimble with a compact bowline.
btw... quite possible you don't need to change the sheaves to go to all rope halyards... have you been able to get a good look at them?
Faster is offline
post #3 of 12 Old 04-10-2017 Thread Starter
The rope never went over the sheaves the way the wire runs, so that is an option. Is the bowline strong enough for cruising? The guy at marine store looked at me like I was crazy when I showed him that piece or mentioned alternative of using a knot.
I have not had a good look. I am leaving for a weekend trip later this week and just saw today that this main halyard line needed replacing. Unfortunately no time to drop mast this week. Ideally I would buy all rope halyard, but I am nervous of running it up and having it get caught and then being SOL for the moment.
fr500c is offline
post #4 of 12 Old 04-10-2017
Minnesail's Avatar
I did change the sheaves in mine, but it was so I could run four halyards instead of two. For my little boat I was able to use 1/4" Control DPX, it would have run fine through the original sheaves.
Catalina 22
on a starboard tack
Minnesail is offline
post #5 of 12 Old 04-10-2017 Thread Starter
Thanks for info. I have an Oday 27. I think I am going to just get 5/16 and tie a halyard hitch. Hopefully strong enough.
fr500c is offline
post #6 of 12 Old 04-10-2017
You should be fine tying the rope on with either knot.
With today's small strong lines I'd expect you could go to all rope without too much hassle.. there's also the possiblity of splicing a strong, small diameter Dyneema or some such into a dacron cover for easier handling.
Faster is offline
post #7 of 12 Old 04-10-2017
colemj's Avatar
It is called a splicing nut: SplicingNut...every line needs a secure loop
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #8 of 12 Old 04-10-2017
Its a cheater nut. When you don't know how to do a proper eye splice or tie a good knot... you use that or something similar.
A proper splice or a bowline (backed up by 2 half hitches for the truly paranoid) will do at least as well as that nut if not better.
zeehag likes this.
Turnin Turtle is offline
post #9 of 12 Old 04-10-2017
colemj's Avatar
I guess the inconvenient fact you've ignored is that the rope broke before the nut.
Not sure how a splice or bowline would have faired any better.
Mark
zeehag likes this.
- Current boat
- Previous boat
colemj is offline
post #10 of 12 Old 04-11-2017
snake charmer, cat herder
zeehag's Avatar
Send a message via Yahoo to zeehag Send a message via Skype™ to zeehag
whip the end of the line so it does not fray. i heat and whip mine.
then learn to splice that which needs splicing.
spliced yacht braid should have whipping at the insertion-- have fun
find ashleys book of knots and read it, play and practice
oh yeah. while ye have ashleys open and you are reading it--practice some of the knots in there. avoid the more complex knots until you have the allegedly lesser knots--the ones that will save your life, not impress your (hahaha) next wife h ah ah ah ah a
formosa 41, cruising tropics
zeehag is offline
Finding the right connector for an outboard clifgray Gear & Maintenance 3 07-15-2016 08:10 AM
rope & wire halyards vs all rope halyards kjango Gear & Maintenance 20 03-02-2013 02:16 PM
what connector? millyman01 Electrical Systems 3 09-24-2012 03:26 PM
rope bridles vs rope travelers allergic1 Gear & Maintenance 1 05-25-2011 03:18 PM
Changing from wire-rope to all rope hoppy Pearson 5 04-18-2011 03:42 PM
