Tachometer fault? - SailNet Community
 2Likes
post #1 of 12 Old 05-24-2017 Thread Starter
Tachometer fault?
The tachometer for my 3YM20 rests at about 200 - 300 rpm with everything turned off. As soon as I turn the ignition on the needle deflects below zero and then when the engine starts it appears to give a realistic - if questionably accurate - reading. Is this an adjustment issue? Or would I be best to source a new tach?
The control panel is an older Yanmar - with a key start. What other questions - if any - should I be asking?
Any insights would be appreciated.
dailymirror is offline
post #2 of 12 Old 05-27-2017
Re: Tachometer fault?
As long as it indexes on zero when the power is applied I think it should be reasonably accurate as it is not capable of measuring anything with the power off. You would assume that the zero mark would be the normal at rest position but apparently not with your tach. If you know anyone else with a Yanmar tach you could look at?
Rocky Mountain Breeze is offline
post #3 of 12 Old 05-27-2017 Thread Starter
Thanks for the feedback RMB. I think I'll live with it for a bit and see what happens. If I don't over rev and flog the engine I think I'll be ok
post #4 of 12 Old 06-02-2017
Ticon 30
dbruce85's Avatar
If you can get ahold of a hand held tach you should check the accuracy of your tachometer. I always wondered why I could never get to up max rpm ( not that I would run there but I was not even close) When my tachometer was reading 2000 rpm it was actually 3000 rpm.
A quick adjustment with the adjusting screw at the back of the tachometer and all is good now. ( I did check it with my handheld and one that belonged to a friend just to confirm the handhelds were right.
RichH likes this.
dbruce85 is offline
The Following User Says Thank You to dbruce85 For This Useful Post:
dailymirror (06-04-2017)
post #5 of 12 Old 06-02-2017
Master Mariner
capta's Avatar
Electric tachs do [B]not[B] drop to zero when the power is turned off, they sit approximately at whatever RPM's they were registering when the power (key) went off. This is normal, relax! As said above, with the power applied (key on) it should zero out until the alternator is putting out, then read something near what you expect in RPM's.
RichH likes this.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
The Following User Says Thank You to capta For This Useful Post:
post #6 of 12 Old 06-04-2017 Thread Starter
Thanks dbruce85. I'll have to see if I can round up a handheld and check it out.
post #7 of 12 Old 06-04-2017 Thread Starter
Ok thanks capta. I'll have to watch more closely and make sure I understand what the tach is showing just as I shutdown.
post #8 of 12 Old 06-04-2017
al brazzi
Kiling the engine and turning the ignition (key) off are two different operations right? I have a manual pull kill and even if its electric its a separate button. Im trying to see a scenario where tach power is killed with the engine shut off, Gas engine maybe.
albrazzi is offline
post #9 of 12 Old 06-04-2017
Master Mariner
capta's Avatar
Yes, that is how it is on most small craft. We push a button to shut down the engine (releases fuel solenoid) then turn the key off. If the key is turned off first, the stop button will not work.
capta is online now
post #10 of 12 Old 06-04-2017
Master Mariner
capta's Avatar
Yes, that is how it is on most small craft I've operated. We push a button to shut down the engine (releases fuel solenoid) or pull a cable (shuts down fuel flow at injection pump), then turn the key off. If the key is turned off first, the electric stop button will not work.
capta is online now
Well, of course, it is all Bush's fault dabnis Politics, Current Affairs, Guns & HOT Topics 22 05-25-2014 10:23 AM
Ferries sailing again after fault NewsReader News Feeds 0 11-17-2011 09:50 PM
Battery? Charger? Who's at fault. sailak Electrical Systems 10 05-22-2011 03:46 PM
Tracking down a ground fault preservedkillick Gear & Maintenance 10 09-16-2009 03:57 PM
Who would be at fault theartfuldodger Seamanship & Navigation 19 08-15-2008 07:51 AM
