yanmar 2gm20f - SailNet Community
 1Likes
  • 1 Post By JimsCAL
post #1 of 10 Old 05-29-2017 Thread Starter
yanmar 2gm20f
Hi all, new to sail boating and having a tough time finding the correct raw water pump for a yanmar 2gm20f.
The boat is a 303 Pearson 1986, with the above mentioned engine. Pulled the pump and cant find a part # on it. So many cross referenced numbers and pump manufactures and prices. Anyone else with this engine have to replace the raw water pump and what way did they go?
Thanks for the help.
thumper53 is online now
post #2 of 10 Old 05-29-2017
JimsCAL's Avatar
Re: yanmar 2gm20f
The short answer is just call your local Yanmar dealer. They will be happy to sell your a new pump. Just be prepared to be take a bit aback. Price is going to be in the $500 range.
An alternative is going to a site like Depco Pump Company. Will typically save some $$.
What's the issue? A rebuild will be the least expensive option.
RichH likes this.
S/V First Tracks
1985 Cal 33-2
JimsCAL is online now
post #3 of 10 Old 05-30-2017 Thread Starter
Re: yanmar 2gm20f
The pump has a drip out of the weep hole.
post #4 of 10 Old 05-30-2017
Re: yanmar 2gm20f
Seals are done. Rebuilds don't last very long, so new is in order. These pumps are a wear item, unfortunately, and they are expensive.
Yanmar protects territories, so I'm not sure you can use the same online resource that I use. But here is there parts listing for your motor.
TOAD Marine Supply
Jeanneau 54DS
Minnewaska is offline
post #5 of 10 Old 05-30-2017
JimsCAL's Avatar
Re: yanmar 2gm20f
As Minne says, the seals have gone bad. So either buy a new one or rebuild it. I had mine rebuilt by the local Yanmar dealer when I had the same issue and it has been running fine for about 5 years. Cost was about half the cost of a new pump. While not for a Yanmar pump, here's a link to an excellent article about how to do it if you want to try it yourself.
Rebuilding A Raw Water Pump Photo Gallery by Compass Marine How To at pbase.com
S/V First Tracks
1985 Cal 33-2
post #6 of 10 Old 05-30-2017
RichH's Avatar
Re: yanmar 2gm20f
If the shaft isn't scored/worn, these pumps can easily be rebuilt by replacing the seals and the bearings.
If youre handy and have access to an arbor press (or very large bench vise) ..... the only 'problem' will be setting up the clearances between the bearings and seals; so, measure carefully using 'wire gages' to obtain the as-installed clearance dimensions. Some Yanmar water pumps sometimes require these special 'clearances' ... so measure before you disassemble.
The bearings and seals can be obtained through common industrial bearing national distributorships such as: Bearings Inc. or Callahan Inc. (every large town in industrial/farming areas usually has both of them).
If you KNOW how to remove such bearings and seals, just take them to such distributorships and have them do the measuring .... or identify the parts by their indicated ID stamped on the body of the part (Yanmar, etc. doesn't make bearings and seals!).
If the shaft is slightly scored or worn, you can consider to 'dress' the shaft and install new bearings and seals to the new dimensions .... if you know how to 'set up' a press fit / interference fit (take careful note of the 'clearances' between bearings and seals when disassembling. The smaller Yanmar distributors and authorized mechanics (usually at larger marinas) sometimes can do this for you; but, at always horrendous 'marina prices'.
Another (much cheaper) source for repair would be your local automotive machinist (every moderate sized town has one) - you ID, purchase and take the new bearings and seals with you. Will be a bargain if the shaft isn't scored/worn.
... material cost for both seals (water and oil seals)will be about ≈$30.00 from an industrial distributor; you might as well change the bearings 'while you're at it'.
About $60-80 for all the needed parts, an additional ≈$75.00 for an automotive machinist to do the 'pressing' and set up .... or you could simply throw about $450 towards a new pump.
RichH is offline
post #7 of 10 Old 05-30-2017
Re: yanmar 2gm20f
Last year a friend changed his out, same engine.. up here in the North the cost was just under $900 CDN uninstalled. During that same week we changed the cylinder head & gasket on our engine for $600... go figure.
Faster is offline
post #8 of 10 Old 05-30-2017
RichH's Avatar
Re: yanmar 2gm20f
The problem is that most major parts/components of obsolete and nearly obsolete engine models carry a hefty inventory charge to make up for the losses incurred for having that part sitting on the shelf burning up a lot of $$ and 'interest' to carry that (dead) inventory. Plus increasingly, in many of the more leftist / 'progressive' parts of the world there are - (yearly) 'inventory taxes' which must be also continually added to the basic price.
For obsolete Yanmars (over 17-20 years since the ending of that model's production run) most 'major' parts are at a minimum of $400 each, .... IF the parts are somewhere still in the 'distributor network' inventory.
After about 25-30 years after the 'end of the model's production run', expect 'nada' to be in stock.
Possible remedy: buy up an old low-hour engine from a wreck, etc. and use that investment to supply your ancient/antique engine with a ready stream of available spare parts.
RichH is offline
post #9 of 10 Old 05-30-2017
Re: yanmar 2gm20f
When the parts guy said $500 for a Johnson 904B pump I said "Gee, I thought it was brass but it must be gold at that price." Even the dealers are frustrated by the way Yanmar changes part numbers seemingly quarterly without reason.
"Just call me TB"
capttb is offline
post #10 of 10 Old 05-30-2017 Thread Starter
Re: yanmar 2gm20f
Thanks for the help, I ordered a new pump and will rebuild the old as a back up.
I need to get it done by Saturday as my wife and I have a 4 day sailing school on the boat.
Mine did take the 500$ pump not the 220$.
Yanmar 2gm20f Ilijanik P30 8 02-28-2013 09:29 AM
yanmar 2GM20F moskalm Diesel 4 01-30-2013 06:30 PM
Yanmar 2GM20F 73Morgan Diesel 10 12-31-2012 06:57 PM
Yanmar 2GM20F Suave Gear & Maintenance 2 05-16-2011 10:33 AM
Yanmar 2GM20F Petar Gear & Maintenance 13 10-02-2009 06:49 PM
