Swing keel won't fully retract? (I think) - SailNet Community
post #1 of 2 Old 06-04-2017 Thread Starter
Hello, so I've been getting my boat ready for her maiden voyage. The last part I'm still a little unsure about is how exactly my swing keel is supposed to work. It'll drop slightly on the trailer but it won't even drop down far enough to reach the trailer. It also sticks out slightly even when I winch it all the way up.
There are two bolt holes in the keel trunk. I assume the hole that is closer to the winch is to keep it retained but it seems like the keel is sitting too low and I'm not sure if there is supposed to be a hole through the keep that the bolt goes through to lock it in? I'm also assuming that the hole further back is to lock it in when it's down so it doesn't pop back up?
I added some pics so you can get a better idea of what I'm talking about. All the pictures I've seen of a San Juan 21 shows the keel fully retracted so I'm pretty sure there is a problem. Any clarification on how this is supposed to work would be greatly appreciated!!!
woodlandbeacher is offline
post #2 of 2 Old 06-05-2017
Re: Swing keel won't fully retract? (I think)
Hello!
Funny enough I am having the same problem on my SJ21 as well. Unfortunately, mine does not move at all even on the trailer. For the holes, take a look at this page Keels - San Juan 21 Fleet 1 . At the end he explains the pin that is needed. It should be out wen bringing the keel up or down but locked in place otherwise.
pduff is offline
Swing Keel or Fixed Wing Keel? Catalina 22 or 25? BRCincy Boat Review and Purchase Forum 60 08-29-2015 01:03 AM
advice -- swing keel vs water ballast vs fixed keel scocchius General Discussion (sailing related) 14 02-26-2015 06:37 PM
Seafarer 24 swing keel, keel pivot? Sailing qualities? skygazer Boat Review and Purchase Forum 44 10-21-2013 10:50 PM
to Swing or Not to Swing ... keel that is nogin General Discussion (sailing related) 30 04-22-2010 10:57 AM
Swing Keel or Fixed Keel for Caribbean Sailing SailorJim123 Boat Review and Purchase Forum 1 02-04-2009 11:15 AM
