New boat finish - failure from below - SailNet Community
post #1 of 4 Old 07-10-2017 Thread Starter
Boat shopping
I'm removing this
Removing
SloopDogg
SloopDogg is offline
post #2 of 4 Old 07-10-2017
kd3pc's Avatar
Re: New boat finish - failure from below
what did the repair look like shortly after the repair/repaint?? Could you see all the flaws that we see in the blue pic?
Does not look good for a long lasting repair...
kd3pc is offline
post #3 of 4 Old 07-10-2017
RichH's Avatar
Boats that originally have 'dark' hull have thicker matting layers under the gelcoat to prevent 'print out' of the subsurface roving layer - 'the bumps' which appear after a newly painted/coated dark hull is exposed to heating in the direct sunlight.
Boats that originally have white or 'light' gelcoat and are later painted 'dark' will usually experience significant 'print out' of the undersurface roving layers when later painted or coated with anything 'dark'.
So, if the boat originally had white gelcoat and someone painted the hull 'dark', this is the leading cause of the development of 'pimples' and other surface discontinuities of the hull surface .... the original polyester in the gelcoat, etc. became 'more' cured due to the increased temperature cause by the 'darker' color that was overlaid upon the original WHITE gelcoat that had a 'thinner' matting layer underneath - quite common with 'painted' fiberglass boats.
RichH is offline
post #4 of 4 Old 07-10-2017
S/V Caper Nonsuch 36
flyrod's Avatar
I realize you said you removed the gel coat, but that looks like gel coat checking or fissures to me.
flyrod is online now
Production boat hard aground because of steering failure MastUndSchotbruch General Discussion (sailing related) 2 02-06-2016 03:43 PM
Failure Mudtimud General Discussion (sailing related) 16 12-29-2012 06:40 AM
Running rigging wear on boat finish.. groundhog Gear & Maintenance 5 09-29-2009 10:17 AM
Schiller's boat has strong finish - Muskegon Chronicle NewsReader News Feeds 0 07-30-2007 10:15 AM
boat finish Bawgy Boat Review and Purchase Forum 2 10-21-2003 07:53 AM
