What tools - Page 4 - SailNet Community
 9Likes
post #31 of 44 Old 08-12-2017
SanderO's Avatar
Re: What tools
Impeller
2 fuel filters
Briefcase with small spools of #14'12,19 and 8 wire, crimpers, butt ends and heat wraps, dlectric grease, amp/ volt tester
Rigging tape
Sail repair tape
Spare shackles
Cotter pins
Wire rings
Spare anchor
Winch handle
Emergency tiller
Bolt cutter
Joker. Valve
Oil absorb sheets
Smaa gauge line like flag halyard
Paper clips
Bungee Cords
Webbbg
spares are not tools
SanderO is online now
post #32 of 44 Old 08-12-2017
chef2sail's Avatar
Re: What tools
Absolutely correct......and your point is????????????
Riddle me this....some suggest wire nuts, some suggest led headlamp....many on the thread suggest items which to only the obtuse would find fault with
You however decide that my post is the only one to chide with your comment......why is that?
Police your own yard. Try and be positive with your comments. Encourage people to share instead of going after them Keep the negativity and criticisms to yourself
seabeau likes this.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #33 of 44 Old 08-12-2017
aeventyr60's Avatar
Re: What tools
I have a few SPARE 5/16, 3/8 and 9/16 combo wrenches....
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #34 of 44 Old 08-13-2017
SanderO's Avatar
Re: What tools
I am not policing anything. Chill out. You set forth a laundry list of spares and nary a tool. The OP asked for tools you didn't provide any tools IIRC. I think you missed the point of what the OP was after.
Spares are very important.. and that is a topic for another thread.
One could argue whether tape or 5200 is a tool or not. I think of tools as mechanical devices that do work or a task:
Definition of tool
1
a : a handheld device that aids in accomplishing a task
post #35 of 44 Old 08-13-2017
oldlaxer1's Avatar
Re: What tools
Originally Posted by Jrthomus View Post
Interesting point but why are wire nuts a no no? Are they prone to corrosion?
Yes, they are very prone to corrosion. ABYC standards do not allow them. American Boat & Yacht Council Standards for Boats E-11 | Ancor
Here is a link to a site that has excellent how to instructions including wiring terminations. A must tool for every do it yourselfer. http://www.pbase.com/mainecruising/boat_projects
s/v Harmony
1973 Tartan 30 #186
Anchorage Marina, Baltimore MD
oldlaxer1 is online now
post #36 of 44 Old 08-13-2017
chef2sail's Avatar
Re: What tools
[QUOTE=SanderO;4029682]I am not policing anything. Chill out. You set forth a laundry list of spares and nary a tool. The OP asked for tools you didn't provide any tools IIRC. I think you missed the point of what the OP was after.
Definition of tool
1
a : a handheld device that aids in accomplishing a task[/QUOTE
Or
anything used as a means of accomplishing a task or purpose:
Education is a tool for success.
Or
The most common use is to describe someone (usually a guy) who is too stupid to know he's being used (he is literally a tool for someone else). Probably the second most common use is for someone who's just an idiot or screw-up.
There are quite a few definitions I think. I understood what the OP was looking for and expanded a little
Tool :Tool | Define Tool at Dictionary.com
Parkville, Maryland
Our blog-
post #37 of 44 Old 08-13-2017
SanderO's Avatar
Re: What tools
[quote=chef2sail;4030090]
Definition of tool
1
Or
Or
this is silly... not worth tit for tat... done
pay attention... someone's life depends on it
post #38 of 44 Old 08-13-2017
al brazzi
Re: What tools
My two favorite tools right now are Sears Handi-cut tool, nothing better for cutting line, and a spare antenna (screw base ) about 4' long with a little ball on the end. It has proved invaluable for fishing wires around the Boat its only long enough to reach through the tight spots. I have so many dedicated Boat tools I keep the heavy seldom used in the dock box.
Don't pass a fishtape to the main panel, it will be live. Should have pointed that out first.
albrazzi is offline
post #39 of 44 Old 08-13-2017 Thread Starter
Jrthomus's Avatar
Re: What tools
Thank you, I spent some time reading at these links, there is a ton of good info here.
Jrthomus is offline
post #40 of 44 Old 08-13-2017
Re: What tools
Gentlemen,
"However I've not worked on sailboats and found myself wondering what could go wrong and what do I need to fix it." Dudes! Can't believe you guys didn't catch that! What could go wrong? Anything and everything! Never ceases to amaze me what can go wrong. Used to annoy me, now I'm like, Hey, another challenge. Happened just today, again. Ditto on the better tools. LOL! Kevin
FloridaBoy is offline
What Tools Should Be On Board? midwesterner Gear & Maintenance 55 04-23-2016 10:47 PM
How do you organize your tools? MedSailor Gear & Maintenance 63 10-28-2012 09:52 PM
Best power tools? sailortrash Gear & Maintenance 48 09-11-2012 12:47 PM
Must have Tools krozet Gear & Maintenance 34 11-04-2009 04:28 AM
New Tools rleslie Gear & Maintenance 2 10-23-2003 01:30 PM
