Anchor chain badly rusted after first 90' - Page 2 - SailNet Community
 6Likes
post #11 of 20 Old 08-29-2017 Thread Starter
Re: Anchor chain badly rusted after first 90'
Never mind - some Google research reminded me that there is a big difference between zinc and galvanized. I need to go with galvanized....
jballou is offline
post #12 of 20 Old 08-29-2017
Sailor
Gladrags1's Avatar
I believe Bacons in Annapolis has the best price on chain. Check them out!
Sent from my iPhone using Tapatalk
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
The Following User Says Thank You to Gladrags1 For This Useful Post:
jballou (08-29-2017)
post #13 of 20 Old 08-29-2017 Thread Starter
Good idea! But they don't show any BBB or Hi-test on their web site. Will call them
jballou is offline
post #14 of 20 Old 08-29-2017
https://www.1st-chainsupply.com/chain/chain.htm
RegisteredUser is online now
The Following User Says Thank You to RegisteredUser For This Useful Post:
post #15 of 20 Old 08-29-2017
JimsCAL's Avatar
Defender is less per foot, no sales tax if out of CT, but you do have to pay for shipping.
Marine BBB Chain
S/V First Tracks
1985 Cal 33-2
JimsCAL is online now
The Following User Says Thank You to JimsCAL For This Useful Post:
post #16 of 20 Old 08-29-2017
pdqaltair's Avatar
Originally Posted by jballou View Post
We have a windless that calls for BBB or Hi-Test 3/8" chain.
West Marine has 3/8" Hi-Test for $6 (galvanized)
Home Depot has Everbilt Hi-Test 3/8" for $3.88 (Zinc plated)
That is a pretty big difference if I'm getting about 150'
Does "Hi-Test" imply a standard that is likely to be the same between WM and HD - or is this a case of "you get what you pay for"?
Thanks!
Google "NACM welded chain specifications" and you will see the actual differences in straighten and size.
No, you do NOT want zinc plated chain. it will begin to rust in a year or even less.
Finally, make certain the shackles are as strong as the chain, a challenge with G43 high test chain.
If the splice will be passing through the windlass, use an irony splice. Much better, though it takes some practice.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
The Following User Says Thank You to pdqaltair For This Useful Post:
post #17 of 20 Old 08-29-2017
I went shopping for new chain a couple of years back. 300 ft of 1/2" high test. I found Defender to be the best deal, shipping and all.
Jeanneau 54DS
Minnewaska is offline
The Following User Says Thank You to Minnewaska For This Useful Post:
post #18 of 20 Old 08-29-2017
Originally Posted by Minnewaska View Post
....300 ft of 1/2" high test.....
You weren't playing around...
post #19 of 20 Old 08-30-2017
Right on. I used to have 200ft that was in good shape, but wanted the extra scope. We have a few anchorages around here that are 30-50ft, if you don't get there early enough for a more shallow spot. Even if you do, you get everyone huddled around you. I love the freedom of anchoring virtually wherever I like. When it blows in the 20s or higher overnight, the anchorages are often sparsely populated, so I can let out some serious scope and sleep like a baby.
I'm tempted to violate my no Block Island in Jul or Aug rule this weekend. No doubt, only the 50ft hole in the middle of the anchorage stands any chance of having a spot over Labor Day weekend.
Jeanneau 54DS
post #20 of 20 Old 08-30-2017
You have been regularly exposing 90 feet to the atmosphere. The other 90 feet has been sitting constantly in salt water. Corrosion is to be expected. As others have said, connect the good 90 feet to some nylon line and dump the rest.
Deina likes this.
alanporter is offline
Anchor chain for PS 37 dhhowes Pacific Seacraft 20 05-27-2015 11:54 AM
Chain to chain connectors on anchor chain kwaltersmi Gear & Maintenance 12 10-16-2013 10:24 AM
Anchor Chain TxLnghrn Gear & Maintenance 9 12-24-2008 06:03 PM
anchor chain SteveCox Gear & Maintenance 11 07-22-2006 08:39 PM
Anchor Chain Jade Sky Gear & Maintenance 0 11-18-2002 09:20 AM
