Custom Built On-board PC / Boatputer Advice - Page 3 - SailNet Community
 9Likes
post #21 of 24 Old 09-29-2017
twoshoes's Avatar
Re: Custom Built On-board PC / Boatputer Advice
Originally Posted by ReefMagnet View Post
And you don't have to throw the monitor away when the cpu dies and vice versa!
Or buy a laptop that has upgradeable/replaceable hardware instead of soldered-in and just replace the CPU or any other component if necessary. All laptop screens can be replaced in less than an hour and run less than $100.
twoshoes is offline
post #22 of 24 Old 09-30-2017
Maple-
A modern laptop, with a modern CPU and OS, is much better at power conservation than an older one. Even Vista has the ability to power down subsystems that are not being used, in order to extend battery life. Now? It is sort of blackmail...You need a 7th Gen Core i7 cpu to really benefit, because you can control how many cores will be used for a task, which in turn will make major power differences. And, the 7th Gen chips will *only* run Win10 (in the MS OSes) which forces you into Win10. Which happens to support new harder (like USB-C) and new i/o controllers that the older OSes just don't and won't support. And Win10 supposedly can control power to unused systems at an even higher granular rate. Some of the Lenono's and others claim to push 13 hours in a slim machine by using all those tricks. (Sure.(G)
So using modern hardware, and SSDs, can really help your game. As to upgrading hardware...yeah, that's a desktop thing. And that really stopped 15 years ago, because other than swapping hard drives? There have been so many basic changes in i/o busses, in memory speeds and form factors...heck even in hard drives, the 2.5" SSDs are half the speed and way more power consumption that the PCI "card" drives that some of the new laptops use. Sadly, simple hardware upgrades buy you less and become less likely every year.
If you can put together a NUC or other light system that does everything you need, great. Bear in mind that even if you get an older Windows OS...when you want to upgrade, it won't be supported in the new hardware. And that of course gets into the cycle of the software expecting to see certain hardware and all the furballs of fun.
A turnkey laptop ain't such a bad way to go. Why they all seem to need 19VDC when nothing inside the box runs at more than 5VDC...damfino, I've been asking that for 20 years and haven't gotten one answer.
hellosailor is offline
post #23 of 24 Old 09-30-2017
So buck downconversion only, no boost needed when host power voltage drops.
+1 on NUC, VESA mount on swivel-racked monitor, 8gig RAM to start, biggest SSD you can imagine ever filling, wireless mouse/keyboard, two external HDDs much bigger to rotate offsite for backups and maybe media transfers
john61ct is online now
post #24 of 24 Old 10-01-2017
CVAT's Avatar
Originally Posted by hellosailor View Post
Maple-
Since when? 7th Gen chips will support and run any OS that supports the instruction set...i.e Linux, iOS, BSD and any other as well as older versions of windows. Please provide your reference data, preferably from Intel, you know the guys that make the chip.
Use your head for something other than a hat rest.
CVAT is online now
Tags
computers , electrical system
Advice on an F. Dekker & Son 1963 custom steel boat Marcool Boat Review and Purchase Forum 7 01-17-2017 02:26 PM
What's one word of advice for animals on board sailing terrapin General Discussion (sailing related) 29 05-09-2014 05:00 PM
24' custom built glass on ply gaff rigged sloop damage assesment Kmenex Gear & Maintenance 39 04-24-2011 04:55 AM
'99 26x: advice & help requested re: center board attilathebun Gear & Maintenance 4 07-08-2009 11:13 AM
Custom-Built Boats Jon Shattuck Buying a Boat Articles 0 11-30-2000 07:00 PM
