Not Getting the All-Chain Thing - Page 48 - SailNet Community
 348Likes
post #471 of 535 Old 05-15-2019
Re: Not Getting the All-Chain Thing
Originally Posted by MikeOReilly View Post
Yes on the physics. I just donít think one should make assumptions about cleats without checking. A dock cleat may, or may not, deal with greater forces. Itís all circumstantial. But one thing is certain, the design force vectors are very likely different.
This is why I donít think it wise to simply assume your stout looking stern cleats are up to the task. Itís specifically why, when rigging a drogue, that the stern cleats on most boats need to be enhanced so as to withstand this new load. Anchoring could produce similar forces.
I really donít mean to belabour this discussion. I do think the stern anchor idea is a useful one for certain boats in certain situations. If your boat wonders and yaws significantly at (bow) anchor, and other solutions havenít helped, then it might be worth giving it a try. But itís not a general purpose approach, and it comes with significant challenges.
I wouldn't suggest that anyone assume their bow or stern cleats and attachments are up to the task of holding in extreme conditions. A lot probably wouldn't and most weren't designed to. That's not to say they can't be used for the purpose of anchoring in anything but extreme conditions. You just don't want the cleats to be the "weakest link".
The rigging of a drogue is a completely different than rigging for anchoring. The drogue will experience MUCH greater loads that an anchor rode would. A drogue has to deal with the boat surfing down large waves where the anchor attachment point deals mainly with wind induced forces.
kmacdonald5 is offline
post #472 of 535 Old 05-15-2019
Arcb's Avatar
Originally Posted by kmacdonald5 View Post
You are a good candidate for dyneema then.
I would be curious to try dyneema anchor line. There don't seem to be many online resources for anchoring with it, but I have been using it for more and more stuff lately. Its really hard to cut, so I am guessing that its way better than nylon for chaffe resistance. It weighs next to nothing it's strong.
It floats though, so I guess you would need a length of chain attached to the anchor shaft and a kellet to keep it from floating up. I am okay with kellets though. I can see them being a pain with a windlass, but when hand bombing the line they really don't seem to be a problem. I just use a 5lb mushroom anchor. Works great.
If I ever get around to buying a new gen anchor I might try it with dyneema.
Minnesail likes this.
Arcb is offline
post #473 of 535 Old 05-15-2019
Originally Posted by Arcb View Post
.... Its really hard to cut, so I am guessing that its way better than nylon for chaffe resistance......
Doesn't dyneema usually have a cover for chafe resistance, because the product itself is not all that resistant? I made my own davit bridle with dyneema and didn't find it difficult to cut at all.
Jeanneau 54DS
Minnewaska is offline
post #474 of 535 Old 05-15-2019
Minnesail's Avatar
I think every post on anchoring technique should be preceded by a brief description of what youíre anchoring, and where. Otherwise the information isnít terribly useful.
So I have a Catalina 22, a 2,300 lb boat that I mostly anchor in protected lakes. Sometimes high winds, but never big waves. I use a 13 lb faux-danforth (oversized for this boat) with 20í of chain and the rest 3-strand nylon.
1. My boat swings like a motherf***er. Itís pretty light weight and the stack pack acts like a small sail, so in any kind of wind I am all over the place. I should build a riding sail, but this idea of stern anchoring is also appealing.
2. I have wrapped my rode around the keel a few times. Again, a small light boat that spins easily. However I donít see how stern anchoring would prevent that.
3. Iíve never had my fake danforth drag. But I have pulled it up completely jammed with mud and weeds, such that there is no way it could have reset had it needed to.
4. Even though Iím in lakes with only small waves, theyíre still annoying when they start slapping. That could be a real downside to stern anchoring. I could see that if it was really hot and I was trying to sleep having the companionway open straight to the wind would be nice, and since the slap would be at the back and Iíd be sleeping up front maybe it wouldnít be too bad? But mostly, if the wind is strong enough that Iím worried about swinging, then itís also strong enough that itíd be uncomfortable to have it blowing straight into the cockpit.
Arcb likes this.
Catalina 22
on a starboard tack
Minnesail is online now
post #475 of 535 Old 05-15-2019
Minnesail's Avatar
I made my lifelines out of dyneema (no covering) and I found it quite challenging to cut. Certainly easier than wire or chain, but definitely harder than nylon.
Catalina 22
on a starboard tack
post #476 of 535 Old 05-15-2019
Old soul
MikeOReilly's Avatar
If you use dyneema for anchor rode will you need a nylon snubber?
CVAT likes this.
Why go fast, when you can go slow.
BLOG:
MikeOReilly is offline
post #477 of 535 Old 05-15-2019
Actually, the biggest upsides is less chafe and way less holding power needed. A violently yawing boat will quickly chafe thru the anchor rode. The wind load on the beam is much greater than from the bow or stern. Point being, if you want to survive a violent storm at anchor, anchor from the stern.
I can't imagine anchoring from the stern in a violent storm. First, since there isn't a chock in the middle of my boats stern, I'd have to use one of the cleats/chocks that are located along the side which would result in being cocked off to one side, or I'd have to fabricate quite a big harness, similar to what multihulls use, Also, since I have no windlass on my stern, if I wanted to shorten the rode during this violent storm I'd have to do it by hand while backing towards it. Since my boat is not a double ender, the waves generated by this violent storm would be smashing into my transom, and since it's a sugarscoop type quite a lot of force would be exerted as each wave broke against my transom and then was blown up onto the deck. My dodger would act as a big wind scoop and the whole cockpit would be exposed to rain and windblown seawater and as soon as I cracked open the companionway, that water would immediately find its way below. If the waves are big and the boat is pitching, my rudder would be exposed to the force of the waves breaking against it so I would worry about it being damaged.
My boat doesn't yaw violently at anchor anyway, especially with my snubber lead over the bow roller but I have chafe gear permanently on my snubber and once the anchor is set I secure it in position so that any chafe would occur to the chafe gear rather than to the snubber itself. If chafe somehow does occur, it's not difficult to fasten a new snubber to the chain and then let out another 30' or so of chain until the new snubber takes the load. I can't say that I've ridden out what I'd call any violent storms at anchor because I always seek a sheltered anchorage in bad weather, but with the precautions I've mentioned, routing the snubber over rollers on centerline of boat and that snubber having chafe gear located at point where it contacts the roller, I've never had any chafe issues at all. Stern anchoring might work in some situations but I think it's a very bad idea for most boats during a violent storm, or even in 2'-3' whitecaps if your boat has a sugarscoop or wide, flat transom. There are lots of very good reasons why the anchors on most boats all around the world are located on or near the bow.
MastUndSchotbruch likes this.
jtsailjt is online now
post #478 of 535 Old 05-15-2019
If you think wrapping your rode around your keel wasn't fun, just imagine what excitement you'd have had if it had been wrapped around your rudder or propeller instead.
I agree wholeheartedly that all our boats have different characteristics so it would be helpful to understand different techniques and opinions if we are told on what boat the incident occurred and under what conditions.
post #479 of 535 Old 05-15-2019
dyneema is very chafe and uv resistant. Much more so than nylon.
post #480 of 535 Old 05-15-2019 Thread Starter
Great stuff...but doesnt stretch
RegisteredUser is online now
Do chain hooks weaken chain? pdqaltair Gear & Maintenance 5 01-14-2014 05:30 PM
Chain to chain connectors on anchor chain kwaltersmi Gear & Maintenance 12 10-16-2013 10:24 AM
What is this this thing? rikhall General Discussion (sailing related) 18 08-31-2011 11:12 PM
Could be the next best thing since... GotTheNotion Gear & Maintenance 9 05-15-2007 10:57 AM
Chain Stopper or Chain Tensioner? 1970Columbia34 Gear & Maintenance 14 03-19-2007 12:43 PM
