2 Shore power connections? - SailNet Community
post #1 of 4 Old 10-23-2017 Thread Starter
I have a Beneteau 381 that has 2 shore power outlets. Several people have asked me why, & really, I have no idea. When I chartered I never had to plug the shore power in. Someone said the other day I only need to plug one chord in & not both (the boat came w/ a double chord).
Anyone know? It does have A/C so maybe that requires the extra power.
Heller Gregory is offline
post #2 of 4 Old 10-23-2017
SFH
Re: 2 Shore power connections?
One is 16A for normal appliances and one is 32A for A/C, washing machine etc.
Have the same on our Jeanneau 53
Sent from my SM-G935F using Tapatalk
SFH is offline
post #3 of 4 Old 10-23-2017 Thread Starter
Thanks! I figured it was for the A/C, I've had enough people ask that I thought I'd ask here.
post #4 of 4 Old 10-23-2017
colemj's Avatar
We have two 30A connections. Our AC panel is divided between them so that one side is shared with the inverter/charger and low amperage circuits, and the other side the AC, water heater, and high amperage circuits. This way, high loads can't be accidentally, run off the inverter if the shore power fails.
If you have two, it is probably the same - your AC panel is split between them, and you should have two main AC inlet breakers on the panel.
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
Solar power instead of shore power Ajax_MD Chesapeake Bay 50 07-11-2017 12:47 AM
Shore power - Reverse Polarity and no power at GFCI outlets tatracy Electrical Systems 17 05-20-2014 11:58 PM
Hooking 110 power cord to shore power? dvuyxx Electrical Systems 16 06-02-2012 10:35 AM
Refitting shore power connections jaschrumpf Gear & Maintenance 16 06-13-2007 03:55 PM
Re: shore power NewsReader Mass Bay Sailors 0 02-01-2007 02:15 PM
