outboard in winter - SailNet Community
 1Likes
  • 1 Post By danr620
post #1 of 8 Old 10-23-2017 Thread Starter
outboard in winter
Guys,
My boat sets in cove on lake in Kansas. If I tip up motor I think it has water still in it. So I guess would freeze up. Do I leave it down in below freezing weather? Just wondering what is the best way. Usually pull the boat out in October.
thanks
Dan
danr620 is online now
post #2 of 8 Old 10-23-2017
Freedom isn't free
Dock
Re: outboard in winter
You won't like my response, but if the boat is on water in freezing weather (inland) wouldn't your bigger deal be a frozen lake? Otherwise you are looking at periods of air temp being below freezing, not consistently below freezing.
Otherwise, your option is the pull the outboard out of the water, and mount it on the rail (above the waterline) in a vertical position that will allow it to drain.
Freedom, a 1983 C&C 32 sailing Smith Mountain Lake, VA
SHNOOL is online now
post #3 of 8 Old 10-23-2017
If it's gonna be down for a season, why not take it home...flush it..and put it in a garage/undercover?
It's one of your valuable team mates.
You can touch it and talk to it at odd hours...your lil buddy...
RegisteredUser is online now
post #4 of 8 Old 10-23-2017
Originally Posted by danr620 View Post
.....Usually pull the boat out in October....
Are you staying in this year?
In any event, I would pull the outboard off, even if you are up on the hard. I just don't believe you can get the internals as clean and dry as you would like and things rust and corrode when left sitting outside all winter.
Jeanneau 54DS
Minnewaska is offline
post #5 of 8 Old 10-24-2017 Thread Starter
Thanks Guys,
Thats what I thought. Sailinguphill is right, with the little cove I put it in, would probably freeze over here while rest of the lake would be clear. It is home.
Dan
SHNOOL likes this.
post #6 of 8 Old 10-24-2017
Freedom isn't free
Dock
Well, now that it is home... time to pull the lower unit, replace the impeller, change gear oil, and make her happy for her long winters nap.
post #7 of 8 Old 10-24-2017
pdqaltair's Avatar
I have not pulled an outboard in 30 years. Neither has anyone in my marina.
Gear oil every 4 years (2 bottom paint cycles). Impeller every 6-10 years, engine oil every year. They always last ~ 15 years, dying from corrosion to ignition system or I sell the boat. I could do more, but my time has value. I might (might not) get a few more years at the cost of 30-40 hours of labor. Doesn't add up to me.
I sail all year. I goes way below freezing, but the water only freezes for a few weeks (brackish tidal). Tipping the motor is enough. On the tender it just hangs down.
Cheers.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #8 of 8 Old 10-25-2017
Moderator
Arcb's Avatar
To answer, the original question (I'm not clear if it's been answered) my approach would be to keep motor down in below freezing temps. Water in the motor wont freeze if it's submerged, but if it's enveloped in cold air, it will.
We are lucky to have a fairly late boating season here in Eastern Ontario. The river often won't freeze up solid until around mid-late december but we do get some very cold boating weather. I keep right on going until freeze up and have never really had problems with a motor trimmed down in the water, aside from being ugly to start.
Arcb is offline
What can i get done in the winter? smallboatlover General Discussion (sailing related) 15 01-10-2013 06:56 PM
Winter in water w/ outboard sidecar7 General Discussion (sailing related) 5 09-03-2009 10:53 AM
winter christinero Living Aboard 4 11-20-2004 01:52 PM
