Winterizing Standing riggging? - SailNet Community
 6Likes
  • 6 Post By RichH
post #1 of 7 Old 12-05-2017 Thread Starter
Chris Arias's Avatar
Hi
I recently read, it is suggested to loosen the standing rigging for the winter and then re-tune in the spring. Now this contradicts another article I read on metal fatigue, that stated loose and then stressed steal cable will increase the rate of fatigue on rigging and shorten their life and a constant tension is best. This article was referencing the proper tension on the rigging is important and a poorly tune rig, one that the lee shrouds slacken and then come under tension when to windward, is bad. The first article is more about relieving tension over the winter.
Can anyone expand on this or have any thoughts?
Thanks
chris
Chris Arias is offline
post #2 of 7 Old 12-05-2017
Lake Sailor
cb32863's Avatar
Re: Winterizing Standing riggging?
Can you post a link to the article? My boats rig does the lee slack all the time and I have mine tuned to the specs of the manufacturer. How are the lee shrouds supposed to stay in tension anyway? They are not under load.
Umquam Porro
Seeker 1992 Beneteau First 235
cb32863 is online now
post #3 of 7 Old 12-05-2017 Thread Starter
At the moment I cant. It was a mental note and i dont know the source right off hand. My guess is I read it in Practical Sailor in the past year but I also subscribe to Sail and World Cruiser as well, but then again I read a lot of books and online articles so that needle is in one of those haystacks. Ill look around to see what I can find.
post #4 of 7 Old 12-05-2017
RichH's Avatar
Hopefully this will point you in the right direction .....
Sailboats typically have aluminum masts and stainless steel rigging.
Such metals expand and contract upon changing temperatures. Aluminum has a higher rate of expansion/contraction due to temperature changes than does stainless steel. In wintertime the Aluminum will contract faster than stainless steel .... the 'shrinking' aluminum mast will unload tension in the rigging.
Fatigue ....
Common (300 series) stainless steel has a fatigue endurance limit of approx 30,000 psi, it also 'can' have a yield strength (permanently changes dimensions) at approx the same 30,000 psi (equivalent to approx. 30% rig tension!!). This is for common stainless steels; 300 series stainless steel can have 'better' values based on 'heat treatment and other metal forming processes'
Fatigue in 300 series stainless 'starts' to become a serious problem when the fatigue endurance limit (~30,000 psi) is repetitively (cyclically) exceeded -- usually at greater than ~1 million load cycles at greater than the fatigue endurance limit (~30,000 psi), at which time there's a high probability that such a 'part' will simply fall apart/shatter from the accumulated fatigue.
So, with your wintertime mast shrinking faster than the stainless rigging, which unloads the rigging; the normal (summertime) ~15% tension in rigging becoming less as it and the mast gets colder; the rigging tension remaining well under the fatigue endurance limit of 30% of ultimate tensile .... there's damn little potential for fatigue in your rigging during wintertime .....
...... unless your boat is heeled over to greater than about 45++ during during a 'blow' in excess of ~Cat 5 and/or any 'gusts' causes extreme mast vibration that would add up to ~1 million load cycles that exceed that 30% tensile strength ....
... the 'real' answer is:
If the rig didn't have severe oscillations from the wind in summertime, it will probably have LESS potential for vibratory oscillations when the rig relaxes during the winter.
You dont need to do 'anything' with the rigging for wintertime, it automatically unloads itself.
RichH is offline
The Following User Says Thank You to RichH For This Useful Post:
Chris Arias (12-06-2017)
post #5 of 7 Old 12-05-2017
Norahsark1's Avatar
For the boat with slack lee shrouds, look for flex in the boat. The mast step is the first place I would look, if it is compressing under load you have a mast that is effectively getting shorter under load and no amount of rig adjusting can overcome that.
If it's not the mast step look at everything else that holds the rig up.
Norahsark1 is offline
post #6 of 7 Old 12-06-2017
pdqaltair's Avatar
I wonder if the issue here is not the rigging, but the sustained force applied to the hull. This is a factor on some light boats.
Heck, I release tension every time I finish sailing, but that is an extreme case and the boat is built for it. But it is certainly not a fatigue issue; the loads are too low at the dock.
I would have some concerns regarding galling the screws by doing this frequently. Hopefully the turnbuckles are bronze (most are, either chromed or with bronze inserts) and lubing EVERY TIME with Tefgel.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #7 of 7 Old 12-08-2017
Lake Sailor
cb32863's Avatar
While that could be an issue, it is rarely the case. As in this tip from Sailing World on maintaining boat speed; "No. 4 Every boat has its optimal rig tension. Find out what it is and maintain it. Most boats sail best with the rig just tight enough so that the leeward shroud starts to go slack when it's blowing 10 to 12 knots."
Umquam Porro
Winterizing GaiaOrion General Discussion (sailing related) 0 10-25-2013 04:04 PM
Winterizing AlanInSeattle Gear & Maintenance 26 01-02-2010 10:46 AM
Winterizing Popsbear Newport 0 11-08-2007 09:33 PM
Winterizing drynoc Gear & Maintenance 4 11-24-2005 02:35 PM
How much winterizing do I need? foxglove Gear & Maintenance 7 09-18-2004 12:22 PM
