Laundry on a Small Sailboat - Page 3 - SailNet Community
 32Likes
post #21 of 33 Old 12-07-2017
Re: Laundry on a Small Sailboat
That's funny stuff, really...
Good post.
RegisteredUser is online now
post #22 of 33 Old 12-07-2017
Sailor
Go when its hot out you will need a lot less clothes
Jim_W is online now
post #23 of 33 Old 12-07-2017
Sailor
Originally Posted by travlin-easy View Post
A free, five gallon bucket works just fine, and you can even mount a pendulum agitator through the lid, which is activated by the motion of the boat. No scrubbing, no work at all, the bucket of water and pendulum does it all for you, while you have fun cruising.
All the best,
Gary
Buckets are getting pricey Yeti is selling one for 40 dollars
Jim_W is online now
post #24 of 33 Old 12-07-2017
travlin-easy's Avatar
Yeti's prices are insane! I don't know about you, but I would never pay $29 for an insulated coffee mug.
Gary
travlin-easy is online now
post #25 of 33 Old 12-08-2017
Few thoughts.
I've read stories about the EcoWash leaking, after a few uses. Never used one, but check that out to see iirc.
I've done my fair share of camp washing. Sinks on a sailboat, streams on a hike, etc. Personally, I've never gotten anything all that clean, by trying to adapt a shore concept to the wilderness.
I've heard of folks using ammonia in a bucket that claim it's the way to go. The ammonia is a strong detergent and reportedly will evaporate from the clothing, after doing it's job. I also believe you can reuse the ammonia, but would need more than the standard bucket. You'd need one with a good gasket. Of course, you need to be sure that chlorine is never mixed, as that creates a deadly gas.
Arcb likes this.
Jeanneau 54DS
Minnewaska is offline
The Following User Says Thank You to Minnewaska For This Useful Post:
Arcb (12-08-2017)
post #26 of 33 Old 12-08-2017
outbound's Avatar
We have the scrubba. Works great but the seam failed so it leaks. The little drain plug is hard to get out. It lasted one season. Then got the device Bill referenced. On a 46’ boat it’s a pain to store. The handle comes off easily but the rest snaps together and isn’t made to repetitively take apart and reassemble. Not a good choice for a small boat. But it does a great job. Would note it’s off the boat due to storage issue but great up at the hunting camp.
If you have two sinks and have only synthetics that’s the way to go. Biggest thing about laundry is to get rid of all cotton clothes. Synthetics will come clean with a wash in salt water and Dawn. Then rinse in fresh. We have RO now so do both in fresh with whatever highly concentrated detergent is available.
Still go to the laundermat for the bedding. Haven’t found a good way to do bedding on the boat
travlin-easy and Arcb like this.
s/v Hippocampus
Outbound 46
outbound is online now
The Following User Says Thank You to outbound For This Useful Post:
Arcb (12-08-2017)
post #27 of 33 Old 12-08-2017
Old soul
MikeOReilly's Avatar
The Scrubba looks like a standard dry bag with, I presume, some sort of rough side. Looks pretty easy to recreate, likely at a fraction of the cost.
The Ecowash’s churning handle and stand was flimsy, but the main tank seemed well built. It never leaked for me, and I did use it quite a bit. Like I say, the main reason I abandoned it was due to the large space it required for storage, and also b/c it is slow to process larger loads. I didn’t find I saved any water using it either (which is why it claims the “eco” moniker I assume).
After years of doing laundry on board the only improvement I’d plan to make to our bucket & fancy plunger is to add a small scrub board.
Arcb likes this.
Why go fast, when you can go slow.
BLOG:
MikeOReilly is online now
post #28 of 33 Old 12-08-2017
+1 for dragging behind the boat although that can also collect a lot of plankton.(G)
You've also got to be wary of ammonia. Among other things it attacks latex, which is why the folks at Windex tell you never to use it on latex (house painted) walls. And it will attack lycra, spandex, other fabrics the same way, eventually breaking the elastic part of them down. Same for the elastic in waistbands. Ooopsie.
Another good reason to sail in a kilt, with no elastic in or under it.(G)
RegisteredUser and Arcb like this.
hellosailor is offline
The Following User Says Thank You to hellosailor For This Useful Post:
Arcb (12-08-2017)
post #29 of 33 Old 12-08-2017
Originally Posted by hellosailor View Post
....You've also got to be wary of ammonia. Among other things it attacks latex, which is why the folks at Windex tell you never to use it on latex (house painted) walls. And it will attack lycra, spandex, other fabrics the same way, eventually breaking the elastic part of them down. Same for the elastic in waistbands. Ooopsie.....
Interesting, most hiking and quick dry things probably contain these things. Bleach definitely kills elastic. Didn't realize ammonia does too.
Jeanneau 54DS
post #30 of 33 Old 12-08-2017
I'm not sure. The quick-dry stuff like Caprilene is basically polyester, I think. No elastic in in. And my good socks are "all wool", if there's any elastic it is just in the tops of them.
Arcb likes this.
looking for a small sailboat D-Cubed Boat Review and Purchase Forum 27 06-10-2016 11:15 AM
Need help to I.D. a small sailboat. partingclouds Boat Review and Purchase Forum 13 10-24-2014 11:59 PM
Crealock 37 survey laundry list brokesailor Pacific Seacraft 8 02-20-2011 09:19 AM
The laundry dilemna StepHB Cruising & Liveaboard Forum 71 09-26-2008 10:45 AM
Looking for small sailboat jrencher Boat Review and Purchase Forum 8 06-20-2006 10:08 PM
