Bottom Paint above the Waterline? - SailNet Community
 1Likes
  • 1 Post By FloridaBoy
post #1 of 7 Old 12-10-2017 Thread Starter
Hello, all you Brainiacs and Engineers! The only place on my Morgan 35 that grows stuff, weed, barnacles. is the water line. And, anywhere paint has worn off, bottom of keel, attachment points of the skegged rudder. I have Trinidad SR on the bottom, scant growth for 4 yrs that I have owned the boat. Don't know if it's the PTFE kind or the Irgarol. I have a friend that just had his boat painted and had the bottom paint extended above the waterline, about 4 inches. Seems like a good idea...Now he's not a lifer like you guys. What do you think? Will it stand up to being out of the water? It looks fine, I mean, not having a traditional strip of one or two colors, on the water line. So, let's hear Ya'. Thanks for your opinions. Kevin
Harvey Hall likes this.
FloridaBoy is offline
post #2 of 7 Old 12-10-2017
SFH
Re: Bottom Paint above the Waterline?
On our Jeanneau 53 the antifouling is extended approximately three inches above the water line.
Has always been like that and never had any issues.
We use International Micron Extra. Dover color. Initially is is greyish but turn into a more greenish color after launch
Sent from my SM-G935F using Tapatalk
SFH is offline
post #3 of 7 Old 12-10-2017
aeventyr60's Avatar
Yep, when yer rocking and rolling outside the confines of the marina the waterline means sweet fook all..extend it up a few inches...
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #4 of 7 Old 12-10-2017
Master Mariner
capta's Avatar
Our present bottom paint and in fact the bottom paint of every boat I've ever owned has extended at least 3" above the waterline and as much as 8" on some. It keeps the waterline clean, if not growth free. No yellow stains or black lines and smudges at the waterline any more.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #5 of 7 Old 12-10-2017
We've owned boats with the boot stripe too low, and it's a PIA to keep clean.
Go up a few inches, saves a lot of trouble.
capecodda is online now
post #6 of 7 Old 12-10-2017
roverhi's Avatar
Most cruisers and anyone in a rolly moorage will have moved the bottom paint up beyond the designed waterline. Most people won't notice it unless it was moved it up a foot or so. Moved my water line up to the top of the boot stripe and painted on a new boot stripe above. Was a big improvement in boats appearance even though the floating waterline remained the same. No more slime on the boot top.
roverhi is offline
post #7 of 7 Old 12-10-2017 Thread Starter
Thanks Folks, I figured I'd get an opinion here, and they are all positive. I don't think I've ever noticed bottom paint above the water line. Then again, I wasn't looking for it. So, above the water line it will be. Be nice not having to scrub that durned water line. I think that took longer than scrubing the slime off the bottom. Thanks again. Kevin
Don Casey: Paint Waterline Stripe with Bottom Paint asdf38 Gear & Maintenance 23 03-05-2016 07:50 PM
Paint over Gelcoat above the waterline. Buzzards Bay Gear & Maintenance 15 01-09-2016 08:59 AM
Paint thinner for soft ablative bottom paint jameswilson29 Gear & Maintenance 7 11-26-2012 01:56 PM
Waterline paint question: How to factor in provisioning weight? chrisncate General Discussion (sailing related) 12 01-13-2011 10:22 PM
What paint below the waterline on a hard dinghy? TaylorC Gear & Maintenance 2 04-20-2009 06:44 PM
