Galvanic isolator messed up wiring - SailNet Community
post #1 of 2 Old 12-17-2017 Thread Starter
I spent the morning trying to figure out why I'm getting through zincs rapidly (6 to 8 weeks).
There are two ground bus strips, separated by a 50A West Marine galvanic isolator. How the boat was wired is that all the grounds, the incoming a/c, the bonding system, the a/c outlets, water heater, everything, apart from the battery charger a/c ground, were connected to one bus, and then the battery charger was connected to the other.
So the only thing isolated by the galvanic isolator was the battery charger. I've put the wiring right : incoming a/c ground to one bus, all the others on the other. The meter reads 0.9V both ways on diode check mode, between incoming a/c ground, and the other grounds.
I just don't understand how it wound up that way. Ill-informed previous owners? It could have been like that from the factory, as the wiring looks original. Has it really been eating zincs for 33 years?
MarkSF is offline
post #2 of 2 Old 12-18-2017
celenoglu's Avatar
Re: Galvanic isolator messed up wiring
Galvanic isolator is only a part of the equation. It only protects the metals from galvanic action that might be caused by other boats. If zincs are depleted so fast, it is better to check your battery connections and related wiring.
celenoglu is online now
Galvanic Isolator capbillh2 Electrical Systems 17 03-16-2017 04:08 PM
Galvanic Isolator wmjr Pacific Seacraft 13 01-16-2014 11:12 AM
Wiring a galvanic isolator Minnewaska Gear & Maintenance 6 05-22-2011 05:25 AM
Galvanic Isolator Question Allanbc Electrical Systems 9 03-16-2011 06:51 AM
Galvanic isolator Minnewaska Gear & Maintenance 1 09-14-2010 11:57 AM
