Can someone identify these fittings? - SailNet Community
post #1 of 3 Old 12-25-2017 Thread Starter
I need fittings so I can connect hoses (otherwise the pump isn't much use). I can't seem to find a name for this type of quick connect fitting to do a search for where to purchase:
BillMoran is offline
post #2 of 3 Old 12-25-2017
Re: Can someone identify these fittings?
It's called a KlickTite port connector, it's my impression they are usually used at the pump inlet and outlet and adapt the connection to some common plumbing size.
KlickTite Port Connectors | Johnson Pump - Marine | Product Detail
"Just call me TB"
capttb is offline
The Following User Says Thank You to capttb For This Useful Post:
BillMoran (12-25-2017)
post #3 of 3 Old 12-26-2017
The clear plastic lid unit is a water filter, the larger unit is a pump ! Both are klicktite units.
mike dryver is online now
Can anyone identify these light fittings for me TQA Gear & Maintenance 6 05-22-2013 08:25 AM
Swaged fittings vs. mechanical fittings yachtthor Pacific Seacraft 24 04-21-2012 04:48 PM
Rigging Fittings TommyD Gear & Maintenance 2 06-01-2010 10:30 PM
Hell fittings? nauticalrich Gear & Maintenance 1 06-17-2003 07:23 AM
Swaging Fittings Tom Wood Gear and Maintenance Articles 0 04-24-2002 08:00 PM
