THRU-HULL For my boat - SailNet Community
 21Likes
post #1 of 28 Old 01-22-2018 Thread Starter
So I need to change the Thru hulls in my boat what is the best material and best thru hulls ? Plastic, steel ,bronze?
mikel1 likes this.
sailforlife is offline
post #2 of 28 Old 01-22-2018 Thread Starter
Re: THRU-HULL For my boat
I heard Groco is a nice brand
post #3 of 28 Old 01-22-2018 Thread Starter
You season sailors does this article make sense or have merit
https://www.sailfeed.com/2013/10/no-...-and-seacocks/
post #4 of 28 Old 01-22-2018
Nothing wrong with good quality bronze stuff. Check out the advice on Maine Sail's great site.
You used the word "plastic" but there are none (or should be none) made solely out of plastic.
Equivalent to bronze in strength are the composite ones from Forespar, and you want the one-piece "93 series" valves. Strong and never any concern about electrolysis.
If you go with bronze, go with a name brand, to be sure of getting a true marine alloy.
1988 Olson 34, by Ericson Yachts.
Sail # 28400
Betamarine 25 (new 2018)
RCYC, Portland, Oregon
olson34 is online now
post #5 of 28 Old 01-22-2018
Master Mariner
capta's Avatar
A good quality bronze thruhull with a real bronze seacock (not a ball valve), from a reputable manufacturer like Groco or Perko would be my choice. Also keep in mind that if you have a cored hull, you must make sure that there is no core where the thruhull goes through the hull. If necessary, dig out the core around the hole and fill that space with epoxy putty so when you tighten the thruhull, you are doing it against a hard surface, not the soft care material of the hull.
sailforlife likes this.
ďBelieve me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.Ē ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #6 of 28 Old 01-23-2018
Composite(plastic) thru hulls will not corrode, but I understand they do degrade over time. Some brands are similar in breaking strength to bronze, others aren't. I can't keep them straight.
Quality bronze thru-hulls and valves (Groco, Perko), when properly installed, will outlast the owner. Note: crappy chrome coated ball valves, often OEM on some production boats, are not the same. I'm slowly changing all mine out.
Steel is silly.
That's my story and I'm sticking to it.
Jeanneau 54DS
Minnewaska is offline
post #7 of 28 Old 01-23-2018
TruDesign is an option.
Jeff_H and sailforlife like this.
RegisteredUser is online now
post #8 of 28 Old 01-23-2018
bigdogandy's Avatar
Dock
Are you sure you need to change all of the thru hulls? Would be curious to hear what problems you're having that require changing them out.......
Andy
Cruising
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is online now
post #9 of 28 Old 01-23-2018 Thread Starter
The guy from SAILLIFE on youtube is using these in his warrior 38 apparently they have won awards. I will read into it Thanks.
post #10 of 28 Old 01-23-2018 Thread Starter
They are plastic so I was told that plastic is no good and I need to change them.
The person that told me that has like 30 years in the business of boat repair.
So I guess thats my only reason they are not having any issues...
How Often Should My Boat's Hull Be Cleaned? Fstbttms Gear & Maintenance 15 01-15-2012 11:16 AM
water in the hull of the boat golfishunt General Discussion (sailing related) 4 09-04-2011 03:51 PM
Boat Hull Condensation RIYachtBroker General Discussion (sailing related) 2 11-05-2009 12:41 PM
blisters, boat hull that is nauticalrich Gear & Maintenance 2 11-22-2001 02:33 PM
HULL , BOAT SPEED nauticalrich General Discussion (sailing related) 9 09-15-2001 11:50 AM
