Bilge paint: any brands to favor or avoid? - Page 2 - SailNet Community
 8Likes
post #11 of 23 Old 02-04-2018
Barquito
Barquito's Avatar
Re: Bilge paint: any brands to favor or avoid?
I would imagine the prep would predict success of the paint job much more than the quality of the paint. I've never painted a bilge, but, I would imagine it would be really difficult to prep on some boats. If there is rough roving, effective degreasing may be difficult, and sanding would be nearly impossible.
Valiant 32
Barquito is online now
post #12 of 23 Old 02-06-2018
I've had a lot of luck with Bilgekote too, and I'm afraid to say my prep was minimal. Just cleaned the surfaces, that's all.
Shame the color range is so limited.
fallard likes this.
MarkSF is offline
post #13 of 23 Old 02-06-2018
Chastened
Ajax_MD's Avatar
Originally Posted by boatpoker View Post
Rustoleum. Been using it for 25yrs. One of the cheapest paints on the market and I've never seen it flake.
I hate you. I could eat off of those surfaces.
Rustoleum makes a lot of products. Exactly what did you use?
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #14 of 23 Old 02-11-2018
Senior Moment Member
SloopJonB's Avatar
Capta is right - prepping a bilge for paint is a lot of work because of all the goo that gets in it. Clean it again & again with degreasers - Spray Nine works well as do Zep products.
Finally, when you think it's clean, wipe it with solvent - acetone or lacquer thinner.
After that, spritz it with water and see if it still beads up - it probably will.
If so, rinse & repeat until it doesn't.
You don't want to sand it before it's squeaky clean or you'll sand the contaminants into the surface.
Not doing this is why you see flaking bilge paint.
boatpoker likes this.
SloopJonB is online now
post #15 of 23 Old 05-27-2018 Thread Starter
Unfortunately, the followup on this thread is that I had a really bad experience with Interlux's Bilgekote. Quite honestly, it's exactly the kind of bad experience I was trying to avoid by asking this question in the first place.
Posting this really bothers me, as I'm worried that someone is going to come forward with something like "didn't you know that you have to kiln fire to get a good coating" or some other accusation that I applied the product wrong. I've gone over the process I followed multiple times and even re-did the entire application on a test piece to see if I could get a better result.
Unfortunately, I'm led to the conclusion that this product just isn't very good. More details in the video.
https://youtu.be/MSU88XMasjE
BillMoran is offline
post #16 of 23 Old 05-28-2018
Bleemus's Avatar
Bill,
Did you sand all the surfaces prior to applying bilgekote? It doesn't hold unless surface is sanded and cleaned with solvent.
oysterman23 likes this.
Keth
Boat Vinyl Lettering and Graphics
Bleemus is offline
post #17 of 23 Old 05-28-2018 Thread Starter
Originally Posted by Bleemus View Post
Bill,
About a jillion people have asked a variant of this same question since I posted that video.
The answer is yes. I sanded all the surfaces and cleaned them with acetone before applying the primer. Then I sanded the primer and cleaned with acetone before applying the bilgekote.
I understand that surface prep is the most common reason for paint failure. I understood that prior to starting this paint job, and thus I've been meticulous about surface prep.
*shrug* at this point, I'm assuming I somehow got a bad batch of paint ... as unlikely as it seems. Nobody else has complained of problems. Many people have reiterated that the product worked well for them. Every piece of advice so far has been "better surface prep" without finding any flaw in the surface prep that I _did_ do.
I have to assume that this is just one of those weird cases where super bad luck screwed things up somehow.
post #18 of 23 Old 05-28-2018
Bleemus's Avatar
That is odd. Even with a rush job on prep always had that stuff dry hard as a rock.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Keth
Bleemus is offline
post #19 of 23 Old 05-28-2018
overbored's Avatar
I your video I see a can of 2333n solvent. did you use it in the Bilgekote? Bilgekote should be used with 333 solvent not 2333n which is for two part polyurethane paints and epoxy . it will slow the drying time down to the point where it will not harden up for many months.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #20 of 23 Old 05-28-2018 Thread Starter
The 2333n was used as a reducer for the Primer, per the instructions on the Primer.
bilge paint ddiesel Gear & Maintenance 1 04-12-2015 09:46 AM
Bilge Paint in the Head? CalypsoP35 Gear & Maintenance 2 01-24-2013 09:50 AM
bilge paint with Barrier Coat? Skipper Joe Gear & Maintenance 2 09-26-2010 02:28 PM
I need a favor... Cruisingdad Gear & Maintenance 25 04-30-2009 10:35 AM
Painting the Bilge, What Paint Though??? Sapperwhite Gear & Maintenance 18 05-22-2008 02:39 PM
