Bilge paint: any brands to favor or avoid? - SailNet Community
 8Likes
post #1 of 23 Old 02-04-2018 Thread Starter
Short version: What is the best brand of bilge paint to buy? Are there any brands that are particularly terrible and need to be avoided?
Long version:
My Tartan has outstanding paint on all parts of the interior fiberglass that I've been able to inspect so far. I don't know if it's original from when the boat was built in 1979 or if some previous owner did a meticulous job of repainting everything.
I'm doing a few projects that involved sanding down to the FRP to get a good epoxy bond, so I'll need to repaint areas. I want to make sure that what I apply is at least as good as what's already there.
I've seen lots of videos with people dealing with crappy bilge paint flaking off due to age. Comparing that to what's in my boat, I'm led to believe that some bilge paints are significantly better than others.
So, that's the question. What brand should should I buy? What experience have people had with specific products?
BillMoran is offline
post #2 of 23 Old 02-04-2018
Re: Bilge paint: any brands to favor or avoid?
Paint in the bilge can result in paint flakes/pieces in the bilge pump. My bilge not painted nor do I intend to paint it.
seabeau is offline
post #3 of 23 Old 02-04-2018
bigdogandy's Avatar
Dock
I am a fan of Bilge Kote. With good prep and application it is incredibly durable. At least that has been my experience.
Andy
Hard Aground
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is online now
The Following User Says Thank You to bigdogandy For This Useful Post:
BillMoran (02-04-2018)
post #4 of 23 Old 02-04-2018
Dirt Free
boatpoker's Avatar
Rustoleum. Been using it for 25yrs. One of the cheapest paints on the market and I've never seen it flake.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
The Following User Says Thank You to boatpoker For This Useful Post:
BillMoran (02-05-2018)
post #5 of 23 Old 02-04-2018
Is that a lasdrop GEN 2 I see?????
sailforlife is online now
post #6 of 23 Old 02-04-2018
Dirt Free
boatpoker's Avatar
Yes it is. nothing in my bilge but dust
Super easy installation
elliowb and sailforlife like this.
post #7 of 23 Old 02-04-2018
Getting one installed this month!
boatpoker likes this.
post #8 of 23 Old 02-04-2018
Dirt Free
boatpoker's Avatar
Hope you are as happy with it as we are.
Once you have the shaft flange off, it is a 10 minute installation.
sailforlife likes this.
post #9 of 23 Old 02-04-2018
One caveat about bilge coatings-- do not assume that the factory painted it.
Our present boat, built by Ericson Yachts, and our prior boat, built by Hinterhoeller yachts, both have their bilge areas gel-coated.
Because it was brushed on, probably with some wax added for curing, it is not a shiny slick surface. It's more of a mat surface finish.
I like it because with some roughing up with 40 grit I can epoxy other parts to it for full strength.
You might find that your interior "hidden" surfaces are also poly gel coat.
1988 Olson 34, by Ericson Yachts.
Sail # 28400
Betamarine 25 (new 2018)
RCYC, Portland, Oregon
olson34 is offline
post #10 of 23 Old 02-04-2018
Master Mariner
capta's Avatar
I don't think it matters which bilge paint you choose, if you've done the prep correctly. There can be everything from wax to oil on your bilge paint or the glass itself and all that's gotta go before you paint, or you will end up with a bigger mess than you started with.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
bilge paint ddiesel Gear & Maintenance 1 04-12-2015 09:46 AM
Bilge Paint in the Head? CalypsoP35 Gear & Maintenance 2 01-24-2013 09:50 AM
bilge paint with Barrier Coat? Skipper Joe Gear & Maintenance 2 09-26-2010 02:28 PM
I need a favor... Cruisingdad Gear & Maintenance 25 04-30-2009 10:35 AM
Painting the Bilge, What Paint Though??? Sapperwhite Gear & Maintenance 18 05-22-2008 02:39 PM
