V-drives, avoid or embrace? - SailNet Community
 8Likes
post #1 of 18 Old 03-02-2018 Thread Starter
After reading the book How Not to Buy a Cruising Boat I am skeptical about V-drives. We are currently searching for our Caribbean cruiser but have passed boats with this drive. Fear I’m bypassing too many great boats.
Thoughts?
"There is nothing, absolutely nothing half so much worth doing as simply messing about in boats." Kenneth Grahame
oomfh is offline
post #2 of 18 Old 03-02-2018
Learning the HARD way...
eherlihy's Avatar
Re: V-drives, avoid or embrace?
Use of a V-drive is a way to gain more interior space in a smaller boat. The saildrive is a different approach to the same problem. My main issue with a V-drive is that it requires that the motor be mounted "backward" - ie. the water pumps, belts, and alternator are aft, and the transmission is forward. This would make changing an impeller or a belt interesting. Transmission service, however, should be a breeze!
I had also seen a V-drive that spewed oil all over the engine compartment as it self-destructed. I suppose that this could have happened with a conventional transmission, but I have never seen this happen.
Our friend Maine_Sail has one on his CS-36T and he seems happy with it.
USCG Licensed OUPV Captain, ASA 101/103/104/105/106/114/118 Instructor - Also certified in Marine Electrical Systems
eherlihy is online now
post #3 of 18 Old 03-02-2018
Yss, motors need to be installed backwards but that does not mean the 'service items' (water pumps etc) are in the wrong place. The good ole' Atomic 4 comes in a special V-drive configuration where these things are all at what would be the back on a straight shaft installation. Very convenient.
I have a V-drive in my boat that, to the best of my knowledge, has been running flawlessly for over 40 years. Annual oil change (very easy, it is right in your face) is all it takes.
amwbox likes this.
MastUndSchotbruch is online now
post #4 of 18 Old 03-02-2018
I had a 1983 boat with a V-drive that has worked fine for 34 years and is still going. Just because the engine is mounted "backwards" doesn't mean access to belts, water pumps, etc. is going to be better or worse. Those were not an issue for me. My only complaint was that access to the drip-less shaft seal (stuffing box) was difficult, but you can't have everything.
flyrod likes this.
Loki9 is offline
post #5 of 18 Old 03-02-2018
dadio917
dadio917's Avatar
i have a brand new V-drive ready to swap the old on in our Valiant. Only 20 years old but the old one is throwing so me oil from the seal. Not terrible but needs repair. was more $ to replace than rebuild but since I'll have it out figured would get a better result. In any case i don't think there is anything inherent with the v-drive that has caused our problem. But since the old one is useless i'll bring it home and take it apart.
Would i buy a boat with a vdrive again? sure. I've changed impellers and belts and it hasn't been terrible.
RegisteredUser likes this.
Dadio917
Valiant 39
dadio917 is offline
post #6 of 18 Old 03-02-2018
cdy
Had one on an old Cruising Cal 36 - wasn't a problem( access to water pump and other items were in the front) - but just another thing that could go wrong - I would not walk away form a boat with it - but all things being equal would prefer to avoid it - I would walk away from a saildrive attached to an older volvo engine - that seems like a lot of problems - and expensive to fix when they do come up
olson34 and eherlihy like this.
cdy is offline
post #7 of 18 Old 03-02-2018
Tanski's Avatar
Does a v drive make a future repower any more difficult or expensive compare to a "standard" drive?
That is a horse head in the box. Not an alien!
Tanski is offline
post #8 of 18 Old 03-02-2018
eherlihy's Avatar
Originally Posted by cdy View Post
i would walk away from a saildrive attached to an older volvo engine - that seems like a lot of problems - and expensive to fix when they do come up
^^^ this! ^^^
post #9 of 18 Old 03-03-2018
Location: On my boat, currently moving around the east coast US
From talking to one shop I would say yes, although honestly I think it is largely because they are less common, and therefore fewer people have experience with them. I am re-powering my CS36T, and doing most of the work myself, and practically speaking I don't see what would make them objectively more complicated (this is my first re-power, so it is also possible I don't know what I'm talking about )
In terms of other access (for impellers, oil filters, etc) the CS36T has reasonable access all around so that is not particularly difficult. I can't speak for other designs. One place that is tight is access to the stuffing box - not impossible or anything, but it is under the engine and is awkward
Cruising on my CS36T
reduc is offline
post #10 of 18 Old 03-03-2018
Tanski's Avatar
LOL That is the boat I was actually thinking about, one for sale I'm thinking about taking a look at now the the weather is improving. Problem is if I buy a new boat I have no excuse left as to why I'm not out cruising.
Tanski is offline
How did you get your spouse to embrace the cruising life? clmartin0721 Cruising & Liveaboard Forum 85 05-08-2015 03:06 PM
sail drives mr.fixit Gear & Maintenance 7 03-15-2010 10:05 PM
Sail drives vs shaft drives? yellowwducky General Discussion (sailing related) 39 01-29-2009 05:50 PM
Sailors embrace race's 'unmatchable appeal' - Port Huron Times Herald NewsReader News Feeds 0 07-10-2006 09:15 PM
Sail Drives whoulihan Gear & Maintenance 4 12-04-2005 06:44 PM
