Does this bilge look normal? - SailNet Community
 3Likes
post #1 of 12 Old 04-28-2018 Thread Starter
Hi All,
My first boat purchase. C-28.
The bilge pump is located forward, but water first collects aft.
Is this normal? Or is there no normal?
Thanks,
wawa2c is offline
post #2 of 12 Old 04-28-2018
Barquito
Barquito's Avatar
Re: Does this bilge look normal?
Couple ideas: If the boat isn't in the water yet, maybe it is blocked at an angle to help the cockpit drain, or if it is in the water, isn't sitting on her lines. It is also possible that that bilge pump was only intended to kick in when water gets a little higher. On my boat, the lowest sump has a hose to a manual pump. It wouldn't be a bad idea to have two pumps, anyway. A small one to sip up small amounts of water more regularly, and a larger one that would only kick in if there was an unusual amount of water in the bilge.
capta likes this.
Valiant 32
Barquito is offline
post #3 of 12 Old 04-28-2018 Thread Starter
It's in the water. There is a 25gal water tank forward which I believe is empty.
I like the idea of two pumps. Would I be laughed at?
wawa2c is offline
post #4 of 12 Old 04-28-2018
Dock
Not at all, in fact it's a common and often recommended setup, to have a large main pump and a smaller sipping one.
Horizons Found
1976 Newport 28
CharlzO is online now
post #5 of 12 Old 04-28-2018
Master Mariner
capta's Avatar
For what? Having a manual back up pump? Folks would be laughing at you if you didn't!!!!!!!!!!!!
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #6 of 12 Old 04-29-2018
Folks who don't have a backup high capacity pump may envy you after a while. The extra capacity pump along with the batteries to power it in an emergency could make the difference between getting a hull-thru plug in place and limping home or calling for a rescue and salvaging the boat.
Do what you feel is prudent to be safe and win the battle against gravity for a while longer.
SeaStar58 is offline
post #7 of 12 Old 04-29-2018
SVGonzo's Avatar
Install another pump. I heard a saying I like, two is one and one is none. Works great well for Sailing.
Sent from my iPhone using Tapatalk
oysterman23 likes this.
SVGonzo is offline
post #8 of 12 Old 04-29-2018
bristol299bob's Avatar
If I understand the pic i think you need to locate that pump to the low point in your bilge, where the water collects, whereever that is. ALso ensure that the limber holes connecting the bilge compartments are clear.
But I'd suggest that you consider two pumps. one small capacity for nusiance water, and another higher up and of larger capacity. Eventually that pump or switch will fail, and at that point you want a backup. I have a small pump as low as possible. it runs occasionally for short periods of time. The second, larger pump is mounted higher and should never run (if it does tun there is a problem). Since it runs so infrequently it lasts a long time. I check both pumps and both switches each time I leave my boat.
we all have lots opinions on brands and types of pumps and switches. The fact is that eventually the pump or the switch will fail, and you'll be happy to have that secondary when it does.
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is online now
post #9 of 12 Old 04-29-2018
Catalina 28 has a manual pump in place also, only source for water should be the stuffing box so it travels from aft under the engine forward to the bilge. Float switch only triggers when there's a few inches in the bilge and can only get it down to 1/2 inch or so. It's pretty normal, in fact, it's a little dry, pump couldn't have got it that dry on it's own. Most Catalina's do drain to forward end of the bilge, perhaps this one is down at the stern.
"Just call me TB"
capttb is offline
post #10 of 12 Old 04-29-2018
chef2sail's Avatar
Two pimps is the norm....plus a manual.
There are limber holes present correct.
bristol299bob likes this.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
Tags
bilge keel
Bilge pump cutoff delay? Narrow bilge Pamlicotraveler Gear & Maintenance 41 11-02-2014 12:44 PM
How much water is normal? Milkjug Gear & Maintenance 29 02-06-2014 04:27 PM
Is this normal rake davidpm General Discussion (sailing related) 25 09-29-2008 09:29 PM
Bilge coming on more than normal dsbentley Gear & Maintenance 13 08-14-2007 01:53 PM
