Glassing Over Thru-Hulls - Page 2 - SailNet Community
 3Likes
post #11 of 22 Old 05-08-2018
roverhi's Avatar
Re: Glassing Over Thru-Hulls
The repair doesn't need to be equal to the hull strength. The boat did just fine with the thru hull giving no strength to the area. Grind a divit enough to lay in 3 or more layers of Fab/Mat with the largest piece going on first and succesively smaller pieces on top of that. Use Fab/Mat, that's cloth with mat sewn to it. Makes for a much stronger, more water proof repair. If you just use cloth could actually get leaking through the weave of even a number of layers and the layup will too resin rich. Would go with epoxy resin to be sure that you get a good bond of the patch to the hull.
roverhi is online now
post #12 of 22 Old 05-12-2018
Sorry to hear the mishap. The boatyard should have visually inspected every thru hull before removing the slings!
I agree with others that you should have a depth sounder. If you try to sell the boat, it will be less attractive without one.
Patching thru hulls is just time very consuming, itís not rocket science. If you would need to pay someone, you might consider just installing a garboard plug, which would take under an hour and would be easy to do yourself (may need a helper on other side of the hull for 15 mins). They come in handy to drain a bilge on the hard too.
Jeanneau 54DS
Minnewaska is offline
post #13 of 22 Old 05-12-2018
Darryl,
I've done something like this twice. The first was when a new set of instruments and transducers where about 1/2 " smaller dia than old one. I glassed in a filler ring. The second time I had a thru hull to pull water in for a hand pump to the sink. My boat was first a fresh water boat now a salt water so I didn't want that hole. I removed the thru hull fitting, pounded a cork in the hole, ground the bevel inside and out, 5 layers of glass and epoxy, a little sanding and paint and you'd never know it was there.
John
jfdubu is offline
post #14 of 22 Old 05-12-2018 Thread Starter
Thanks all. I ended up glassing over both. Turns out I have an externally ballasted keel which I didn't know, I thought in was internal. I was grinding my bevel and saw some shiny lead and that made my decision for me as far as glassing across the joint. I ended up making kind of a half moon repair and then really beefed up the inside.
I do plan on still using my depth sounder, I just am going to mount in inside the hull to where it's sounding through a portion of solid glass. I'd rather be a meter off in depth than have another hole that can potentially cause me problems. It was leaking too it looked like, but just much slower.
Attached are some pictures, I have to head out there tomorrow to quickly sand the fairing down and throw some paint on and she's done. Thank you everyone for the help!
IMG_20180508_122419918_1526126185975.jpg   IMG_20180508_172606162_1526126204280.jpg   IMG_20180509_161525304_1526126219630.jpg
darrylcf is offline
post #15 of 22 Old 05-12-2018 Thread Starter
Knotmeter
IMG_20180508_131804412_1526126354030.jpg   IMG_20180508_183644976_1526126364547.jpg   IMG_20180509_161511015_1526126377040.jpg
darrylcf is offline
post #16 of 22 Old 05-12-2018
A depth meter inside the hull does not have to be inaccurate.
I think a depth meter that is off by a meter is pretty useless.
paulinnanaimo is offline
post #17 of 22 Old 05-16-2018
SeŮor Member
ottos's Avatar
If it is consistent, that's not so much of a problem.... YMMV
ottos is online now
post #18 of 22 Old 05-16-2018
If it's consistent there is no issue at all, just enter an offset into the display or instrument system. I set mine up to display water below the keel to save people from remembering our draft and doing the math.
ottos likes this.
jarcher is offline
post #19 of 22 Old 05-16-2018
How silly of me to suggest that instruments should be accurate.
post #20 of 22 Old 05-17-2018
lillia28's Avatar
Location: Central New Jersey, sailing on the Navesink River and Sandy Hook Bay mostly.
darryl,
What did you fill the hole with? The red stuff looks like bondo to me, which is not good to use below the water line. If is is not, just ignore this post, but if it is you should replace it with something that is designed to work below the waterline. Epoxy is best but there are polyester resins that will work.
lou
lillia28 is offline
Glassing a old wood hull. Agri Sailboat Design and Construction 24 07-17-2012 08:33 AM
Glassing hull GreenEarth General Discussion (sailing related) 18 06-19-2009 11:52 PM
glassing upside-down.... purvisgs Gear & Maintenance 4 04-11-2008 06:16 PM
Glassing Question pirateofcapeann Gear & Maintenance 6 05-29-2003 02:58 AM
Glassing Hull GreenEarth Gear & Maintenance 0 06-24-2001 03:13 PM
