Sourcing approriate lumber for strip ceiling - Page 2 - SailNet Community
 8Likes
post #11 of 17 Old 05-27-2018
Re: Sourcing approriate lumber for strip ceiling
Everyplace sells Ipe, one of several woods called "ironwood", for decking. That puts some limits on the size (i.e. 1x5?) but you can always have that ripped to the size you want. If you need longer strips, you're off to find a real lumber yard. Best done locally, since shipping lumber is rather pricey.
hellosailor is offline
post #12 of 17 Old 05-27-2018
Ipe is cool stuff. It's quite heavy though. Almost twice the weight of sapele or mahogany.
May or may not make a difference depending on the boat and how much of it is used...
travis.taylor is offline
post #13 of 17 Old 05-27-2018
Cedar...
Relatively inexpensive
Avail at big boxes
Lightweight
Very easy to work with.
Stain to any shade..or not
Thinking ipe is just nuts....off the rails
kiss...
oysterman23 and lillia28 like this.
RegisteredUser is online now
post #14 of 17 Old 05-27-2018 Thread Starter
Here's something I had not thought of: Chuck Rose, of "Cruising LeaLea" fame, brought up the possibility of using plywood strips rather than solid lumber. Said he had seen it done, with excellent results.
This appeals to me a lot. It would save me a fortune, and be easy to do. I'd use marine-grade, Sapele-veneer plywood, thoroughly sealed with penetrating epoxy, and varnished.
If the idea is sound, what thickness do you guys think would be best? Would 6mm be enough? That's just a hair under 1/4". Better off with 9mm maybe?
Speaking of sapele veneer, I've always thought that's what the manufacturer used on my boat. Am I right?
oysterman23 and travis.taylor like this.
dixiedawg is offline
post #15 of 17 Old 05-27-2018
A perfectly sound approach. I actually really like the aesthetic of the contrasty routed edges of plywood finished and placed in a tasteful way..
post #16 of 17 Old 06-01-2018
You're close enough to Ft. Lauderdale to try Constantines Wood Center - Woodworking Supplies and Tools - Fort Lauderdale, FL they are a woodworking shop that stock veneers and lumber for cabinetry and other fine woodworking trades. I know them from their previous location in the Bronx, NY.
Among other great resources, they sell a "veneer sampler" kit with something like 50 slices of labeled veneers in it. It is a dangerous kit, it exposes you to the lust for many fine and exotic wood that can be had.(G)
If they don't have what you need, they'll certainly be able to tell you if there's any local source for it. Craftsmen, not clerks.
RegisteredUser likes this.
post #17 of 17 Old 06-01-2018 Thread Starter
Thanks for the recommendation! I'll give 'em a look!
Crowd Sourcing Survey by Suffolk University jtulls General Discussion (sailing related) 0 04-23-2015 08:43 PM
Sourcing a resonaable Bimini Mariner777 Gear & Maintenance 2 07-02-2011 08:31 AM
Condensation on the ceiling hArpOoN Boat Review and Purchase Forum 21 03-21-2008 12:27 PM
need teak lumber for repairs Missionary Gear & Maintenance 2 09-11-2007 07:49 PM
teak lumber gail57 Gear & Maintenance 10 02-12-2003 05:11 PM
