SailNet Community (https://www.sailnet.com/forums/)
-   Gear & Maintenance (https://www.sailnet.com/forums/gear-maintenance/)
-   -   Sourcing approriate lumber for strip ceiling (https://www.sailnet.com/forums/gear-maintenance/320986-sourcing-approriate-lumber-strip-ceiling.html)
dixiedawg 05-26-2018 11:33 PM
I'd LOVE to have a ceiling of teak strips, but the lumber would cost more than the boat. In my area, there are no lumber places other then HD and Lowes, who carry only oak and poplar.
Can anyone suggest an affordable but sufficiently durable species of wood, and where the heck to find it?
If I am unsuccessful in my quest, I will simply use foam headliner, but I sure would prefer wood. Many thanks. :)
elliowb 05-27-2018 02:27 AM
Re: Sourcing approriate lumber for strip ceiling
If you have some time, I'd suggest that you sign up for Woodcraft's e-mail alerts. I found a great deal on some Honduran Mahogany. Honduran mahogany is often used in marine environments and while it's not as rot resistant as teak, it's much better than many other alternatives. It also will blend nicely with teak. You'll probably need access to a thickness planer and a table saw, but if you were considering teak anyway, I'm assuming that you may already have the tools.
-- Bill
Belle Voile
PSC 34
travis.taylor 05-27-2018 03:38 AM
Sapele is cheap, available, and absolutely beautiful. Not bad to work with and has a pleasant but light scent.
Sorta like cedar with a tiny hint of oak. A soft scent. Ahhhhh...
It compares quite closely with Honduras Mahogany in rot and insect resistance, but is slightly stronger (and very slightly heavier), and much harder.
I've found it to be relatively forgiving of bending to easy large radii (such as a hull liner) when its hardness is considered (harder than maple actually), but suggest you stick to nice, long, straight grained planks if that is your use.
Afromosia is nice stuff, too. Half the price of Teak, but twice the cost of Sapele.
Iroko would be an excellent compromise as well. Its price falls between that of Afromosia and Sapele.
rpludwig 05-27-2018 06:08 AM
+1 for Sapele, have used it for a galley rebuild on our boat and exterior doors (not on boats) for years.
Try Hardwood Lumber & Millwork in Lakeland, haven't used them but their reviews are excellent. I expect they can plane and rip what you need, if you're not equipped to do so.
ianjoub 05-27-2018 10:41 AM
Live oak used to be the go to for ship building. It is growing all around you.
lillia28 05-27-2018 11:20 AM
While at HD look at closet liners. They used to have some cedar paneling that I always thought would make good ceiling. It comes in bundles of 20 square feet or so for on the order of $20.00. The cedar also has a slight but pleasant aroma. I bought some for the boat, but my wife insisted I experiment with a closet first. Cedar has a long history aboard ship.
Always remember that teak became the"preferred" wood for marine use because it was the cheapest available material.
Lou
Capt Len 05-27-2018 11:24 AM
Is it a ceiling OR a head liner you want? For head liner yellow cedar ,cheap ,durable easy to work. Light colour can be good unless you want the dark man cave look.
elliowb 05-27-2018 01:23 PM
Good point. Slats of teak are frequently used as ceiling (i.e. on the inboard sides of the hull). However, I don't think I've ever seen it used on the overhead. I'm not sure to which the OP is referring.
-- Bill
Belle Voile
PSC 34
dixiedawg 05-27-2018 01:54 PM
Yes, I'm referring to the ceiling, as in the inside of the hull - not the overhead.
I'm in a time crunch, will be back this evening. Great replies, thanks all!!
lillia28 05-27-2018 02:50 PM
I assumed he was talking about ceiling, since that was the word he used, and my response was regarding ceiling not headliner. That being said I've seen bead board used as headliner, and it doesn't look bad. I considered it, but could only find 1/4 inch which was too difficult to would with.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
