Transmission Oil - Page 2 - SailNet Community
 4Likes
post #11 of 21 Old 05-29-2018
overbored's Avatar
Re: Transmission Oil
Profile says CS 33 so a shaft drive. the 3ym30 would be a refit
"GOLD RUSH" PRINDLE 16
overbored is online now
The Following User Says Thank You to overbored For This Useful Post:
dailymirror (05-29-2018)
post #12 of 21 Old 05-29-2018
JimsCAL's Avatar
The 2GM and 3GM engines use engine oil in the transmission. Mine always looks clear when I check it. Some of the larger engines use ATF. Sounds like yours has engine oil in it.
Edit: Here's the manual. Page 33 says #20 or #30 engine oil in the transmission.
http://j30.us/files/2YM15-Operators-Manual.pdf
S/V First Tracks
1985 Cal 33-2
JimsCAL is online now
post #13 of 21 Old 05-29-2018 Thread Starter
Yes it is. Original was a Burke. Probably spelled that wrong. But yes YM30 was a refit.
dailymirror is offline
post #14 of 21 Old 05-29-2018 Thread Starter
Yes thatís what my manual says too. I was expecting to extract something more amber - ish. You know, like oil. When it looked so colourless it threw me. Itís a Kanzaki KM2P-1 transmission. Shop manual recommendation is 10W-30.
post #15 of 21 Old 05-31-2018
The oil as recommended is 30 grade MONO engine oil, (not a gear oil) , all of us older sailors will recognize mono grade oils used to be the norm!!!, these mono grade engine oils are still available but you need to look a little harder to find,
In hot climates a MONO grade 40 is quite often recommended over the 30 weight oil, again these are regular engine oils and correct for many transmissions, I see this all the time as many manuals are badly written as the which oil is required, if using ATF be careful of the SUFFIX letter as this is important, All ATF's are not the same,
When using the correct 30 weight engine oil in your transmission it will not change color and turn black, it will remain clear in color although over time it may get slightly thicker
SO - look around for MONO grade engine oil 30 or if in hot climates 40
Eagle5Eagle5 is offline
The Following User Says Thank You to Eagle5Eagle5 For This Useful Post:
dailymirror (06-01-2018)
post #16 of 21 Old 05-31-2018
I would be leery of using ATF in a plain gearbox. From the sound of things if your gearbox does not specify an oil I would probably run with the straight 30 or 40 weight depending on you sailing climate.
Rocky Mountain Breeze is offline
The Following User Says Thank You to Rocky Mountain Breeze For This Useful Post:
post #17 of 21 Old 06-01-2018
celenoglu's Avatar
Although originally gear oil was recommended for Yanmar. Later they changed their recommendation to normal engine oil. Please try to find latest service manuals from yanmar for oil recommendation. If you cannot, use the same oil you are using for the engine.
celenoglu is online now
The Following User Says Thank You to celenoglu For This Useful Post:
post #18 of 21 Old 06-01-2018 Thread Starter
That sounds an awful lot like what I saw on board my own boat... Right now the transmission has the oil recommended in my manual - SAE 30.
post #19 of 21 Old 06-01-2018
If the oil is clear in color it may be synthetic!?? Sae 30 motor oil is a non detergent, non foaming oil not for Diesel engines, mostly used as a lubricating oil.
john walsh is online now
post #20 of 21 Old 06-01-2018
Eagle, do you know if Yanmar recommends SAE 40? I ask because, for some reason, SAE 30 is no longer available in Brazil (as far as I can tell), but they still sell SAE 40. I always used SAE 30 in my Yanmar 3GM30f for both the engine and gear box. I'm in doubt about whether it's better to use straight SAE 40 in the gear box or a 15W30. It's tropical here, although it can be cool(ish) in the winter some days.
VindŲ 50
copacabana is offline
Transmission oil change solution? bwindrope Gear & Maintenance 12 03-08-2013 11:50 PM
Yanmar transmission oil sailak Diesel 7 08-17-2011 01:19 PM
Yanmar 2GMF Transmission Oil? dacap06 Gear & Maintenance 4 04-19-2010 11:03 PM
Transmission oil analysis interpretation Petar Diesel 5 03-27-2010 10:25 PM
transmission oil for diesel engines pegasus1457 Gear & Maintenance 7 10-25-2007 12:18 PM
