Transmission Oil Cooler set up? Questions - Page 2 - SailNet Community
post #11 of 13 Old 06-04-2018
Re: Transmission Oil Cooler set up? Questions
Now you have to decide wheather to run fresh or salt thru it;
Capt Len is online now
post #12 of 13 Old 06-04-2018
Raw water is going to be much cooler, I would think.
Jeanneau 54DS
Minnewaska is offline
post #13 of 13 Old 06-04-2018
Nobody asked my opinion on this matter but here it is anyway. Provided the HX is large enough to be of real use,(often not the case) the engine water coming out of it is cool enough to be effective pressed against the trannie before it meets the thermostat housing Disadvantage ,more care in hoses required to prevent an air lock bubble. Advantage. no salt corrosion and potential for salt intrusion ( tube type oil/ water hx) Salt water in gears not good and then the w/oil mix overflows to bilge ,not good. .Pencil zincs don't last very long. If anti syphon is . last thing in line before the exhaust lifter ,a hole /leak in any part will flood/sink the boat. In comparison, finding some antifreeze where it ought nought is no biggie.
Transmission Oil dailymirror Gear & Maintenance 20 06-01-2018 04:12 PM
Removing Yanmar 4JH2E oil cooler bhcva Gear & Maintenance 0 09-29-2017 11:08 AM
oil cooler for a perkins 4.236 skibum54 Diesel 0 03-19-2013 07:08 PM
Yanmar transmission oil sailak Diesel 7 08-17-2011 02:19 PM
Perk 4.108 oil cooler fitting nimbusgb Diesel 3 08-25-2010 09:23 AM
