Wheel pilots - which one? - Page 2 - SailNet Community
 1Likes
post #11 of 17 Old 07-29-2018
TakeFive's Avatar
Re: Wheel pilots - which one?
Originally Posted by timangiel View Post
It works for awhile then suddenly steers me way off course for no apparent reason. Iíve tried replacing the flux gate compass but it didnít fix the problem.
Close-hauled, following seas, or both?
Have you adjusted gain and response?
Did you calibrate by driving around in circles?
All these are things youíd need to do with a new autopilot.
Have you checked in at the Raymarine product support forum?
Rick S., Swarthmore, PA
USCG Certified Captain, OUPV and 50 Ton Master
2001 Catalina 34MkII Tall Rig Wing Keel Breakin' Away, Universal Diesel M35B, Mantus 35 lb. anchor, sailing out of Rock Hall Landing Marina
TakeFive is offline
post #12 of 17 Old 07-29-2018 Thread Starter
timangiel's Avatar
It happens under any conditions including perfectly flat seas motoring. It will run flawlessly for maybe a couple of hours. Then suddenly without warning will make a hard turn and go off course like 70 or 80 degrees. Yes I have done the go around in circles thing but still have the problem, no I have not been on any Raymarine forums, I didnít think I would get much support for a 25 year old wheel pilot, but maybe Iíll check it out. Iím at a point where Iím happy to just replace it, but was wondering if there were any pros or cons to consider between the previously mentioned models.
Sent from my iPhone using Tapatalk
timangiel is online now
post #13 of 17 Old 07-29-2018
FYI, Iíve owned both the ST4000+MkII (on prior boat) and ST4000 (on current boat). MkII was nicer than ST4000, but not enough to justify upgrading my current one. A new $20 belt fixed all my problems.
I have read about the ST4000. It appears to be a problematic unit. Even a decade ago people were replacing it. If it works for you no reason to replace it but if it gives you fits no reason to work too hard to get it running.
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is offline
post #14 of 17 Old 07-29-2018 Thread Starter
timangiel's Avatar
Thatís pretty much what I was thinking. If all it needed was a belt then fine I would fix it but I think my issue is deeper than a simple fix. We went on a day sail today and I tried it in the wind vane mode and it was fine so it still has some usefulness, but I still want to replace it.
post #15 of 17 Old 07-29-2018
TakeFive's Avatar
When it suddenly goes off course by 80 degrees, does the autopilot direction setting change to the new course? You really should post your issue on their support forum. Iíve never had a problem getting diagnostic help due to age of my instruments.
TakeFive is offline
post #16 of 17 Old 07-30-2018
watching this post because I have the same issue with my ST4000.
It works fine for 1 hour or 2 then stops and the off course alarm goes off. Push stand by, then auto again it works for 10 seconds then stops. Hard to diagnose what the issue is, getting hot? The motor (drive unit) is fine.
SVTatia is offline
post #17 of 17 Old 07-31-2018 Thread Starter
timangiel's Avatar
You can still get a replacement flux gate compass but that doesnít sound like a compass issue. I thought I read somewhere that the newer drive units work with that control unit, but if youíre sure your drive unit is ok that wonít help you. If anything goes wrong with the control unit, you either can try to find a used one online and and take a chance or spring for a new wheel pilot. I believe my issue is in the control unit, and I have no interest in a used one. Let me know what you end up doing.
Which wheel pilot will fit on a Lewmar folding wheel zipperdawg Cruising & Liveaboard Forum 2 05-16-2018 01:01 PM
Wheel to Wheel Conversion Hush34 Pacific Seacraft 3 04-06-2016 07:18 PM
Last one for tonight. Tiller pilots northoceanbeach Gear & Maintenance 15 09-09-2014 04:27 PM
Using Wheel Pilots Mark Matthews Cruising Articles 0 08-18-2002 09:00 PM
Simrad vs. Navico Tiller Pilots jamesmm Gear & Maintenance 4 11-03-2001 04:03 PM
