beathing apparatus for or bottom maintenaince - Page 2 - SailNet Community
 16Likes
post #11 of 53 Old 07-31-2018
Moderator
MarkofSeaLife's Avatar
Dock
Re: beathing apparatus for or bottom maintenaince
Originally Posted by BarryL View Post
Hey,
A friend and I split the cost of a Hoohak and we will share it.
I'm in Amsterdam and hadn't thought of that.
wymbly1971 likes this.
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #12 of 53 Old 07-31-2018
Originally Posted by capta View Post
That sounds like an incredibly dangerous setup. There is a very good reason that noncommercial hookas do not use hoses longer than 30 feet. Unless you are a certified diver I would recommend that you do not use that 75' setup until you have your diving certification. But hey, it is your life!
75 gets me around the boat without resetting.
MarkofSeaLife likes this.
RegisteredUser is online now
post #13 of 53 Old 07-31-2018
Master Mariner
capta's Avatar
So does 30' from amidships, unless your boat is over 60 feet.
CVAT likes this.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #14 of 53 Old 07-31-2018
Guyfromthenorth's Avatar
Originally Posted by Lazerbrains View Post
That is a good idea - how do you attach the scraper to the pole, though?
Not sure how they were attaching it, but I would use black electrical tape with a decent amount of turns on it. We use it all the time at work (in field and around aircraft). If you stretch it when you apply it the tape tries to shrink and hangs on incredibly strong.
Some youtube videos, nothing fancy
Guyfromthenorth is offline
post #15 of 53 Old 07-31-2018
My marina has a long pole with an 18 inch brush/scraper and a small fender zip tied under it. So you just shove it under the water and the buoyancy from the fender keeps it pressed tight to the hull, you only have to use force to get it down. The pole itself is a long piece of 1.5 inch pvc and various fittings and such at the end for the other bits.
tschmidty is offline
post #16 of 53 Old 07-31-2018
Its 12 volt and will sit at the bottom of the companionway. The leads are 6 ft.
I well understand you do not like my 75 ft hose.
post #17 of 53 Old 07-31-2018
Moderator
Dock
Even the forums biggest idiot knows the difference between 75 feet down and 75 feet un-down.
colemj, denverd0n and SchockT like this.
Sea Life
post #18 of 53 Old 07-31-2018
Master Mariner
capta's Avatar
If only it was that easy to clean the bottom of a boat! rotflmao
Never mind the running gear.
capta is online now
post #19 of 53 Old 07-31-2018
Master Mariner
capta's Avatar
Human nature being what it is, do you honestly think if someone has the ability (and no depth gauge) to go down beyond 30 feet, that sooner or later they won't? What if they dropped something in 45 feet of water? Wouldn't most uneducated (diving related) chance it?
That is why the reputable hooka manufacturers only sell 30' hoses with their rigs.
capta is online now
post #20 of 53 Old 07-31-2018
Moderator
Dock
I read between the lines of the original post.... I think he says his health precludes breath holding. So I gather he would stick to the surface.
As instruction on anything says: for intended use only. One should blow their nose with a tissue not shove the whole box up.
I did wonder if his health is that bad it's probably better to hire someone to do it.
denverd0n likes this.
Sea Life
Bottom paint - soft bottom inflatable Maine_bill Gear & Maintenance 6 03-15-2015 04:03 PM
Apparatus for moving rain water in to boat with vent feature steel Gear & Maintenance 4 09-01-2012 04:18 PM
Bottom Paint for Trailerables stretch63 General Discussion (sailing related) 4 01-26-2001 10:23 AM
To Paint bottom or not? rightlife Gear & Maintenance 0 01-02-2001 09:40 PM
Bottom Paint for Racing dwyergreen Gear & Maintenance 6 01-01-2001 05:41 AM
