beathing apparatus for or bottom maintenaince - Page 6 - SailNet Community
 16Likes
post #51 of 53 Old 08-08-2018
Learning the HARD way...
eherlihy's Avatar
Re: beathing apparatus for or bottom maintenaince
I once needed to borrow a 12VAC hookah from a friend who maintains a charter fleet. He had been using his hookah for years. The compressor was labeled "Central Pneumatic."
I believe that it was this one:
After I changed my zinc, I returned it and have not borrowed it again.
USCG Licensed OUPV Captain, ASA 101/103/104/105/106/114/118 Instructor - Also certified in Marine Electrical Systems
eherlihy is online now
post #52 of 53 Old 08-08-2018
denverd0n's Avatar
Originally Posted by PhilCarlson View Post
The compressor on a hookah, or that the dive shop fills tanks with is different.
No, it's not. As has been mentioned several times, all of the commercial hookah systems use compressors that were originally designed for other purposes. NO ONE builds a compressor from scratch specifically for use in hookah systems.
And, by the way, I was planning to add an air filter anyway.
The question remains... The Pacbrake HP625 -- based on its specifications -- appears to be very well suited to hookah use. So I'm still wondering if anyone has built a 12 volt system around it. At this point, I'm beginning to suspect the answer is "no."
denverd0n is online now
post #53 of 53 Old 08-08-2018
PhilCarlson's Avatar
Dock
OK, well I guess I should have said "compressor system."
Good luck.
PhilCarlson is online now
Bottom paint - soft bottom inflatable Maine_bill Gear & Maintenance 6 03-15-2015 03:03 PM
Apparatus for moving rain water in to boat with vent feature steel Gear & Maintenance 4 09-01-2012 03:18 PM
Bottom Paint for Trailerables stretch63 General Discussion (sailing related) 4 01-26-2001 09:23 AM
To Paint bottom or not? rightlife Gear & Maintenance 0 01-02-2001 08:40 PM
Bottom Paint for Racing dwyergreen Gear & Maintenance 6 01-01-2001 04:41 AM
